For mastering loop and nodal analysis, several e-books and resources are recommended, including academic materials from schools and Google Scholar for specific problems. PowerPoint presentations and online articles can provide additional insights into the methods. Visiting a library to find books on circuit analysis is also suggested, as these texts are foundational in electrical engineering. Engaging with knowledgeable peers or forums can further enhance understanding and implementation of these techniques. Utilizing these resources can significantly improve problem-solving skills in loop and nodal analysis.
#1
AK2
39
Could u guys reccomend some e books for loop and nodal analysis . I am having some problems implenting the methods to solve poblems. or may be u could give me some tips
Some e-books that are creditable are mostly from your school or I would search the Google scholar website for the particular problem.
Another tip is to go the library and borrow books that say circuit analysis or circuit principle ,etc,.. They are everywhere since they are fundamental of electrical engineering technology.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable?
For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them.
My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
