Relationship between surface tension and the shape of a liquid drop
The relationship between surface tension and the shape of a liquid drop is fundamentally linked to the minimization of free energy, which favors a spherical shape in the absence of gravity due to positive interfacial energy. In contrast, negative interfacial energy promotes mixing and increases interfacial area. The discussion highlights that the atomic origins of interfacial energy are complex, but the focus can remain on the concept of dividing surfaces without delving into atomic details. When a drop is on a surface, both cohesion (intermolecular attractions within the liquid) and adhesion (attraction between the liquid and the surface) play crucial roles. The contact angle is a key factor; a higher attraction between the liquid molecules and the surface results in a less spherical shape, emphasizing the importance of these forces in determining the drop's geometry.
yjk91
i don't know how to describe the relationship between surface tension and the shape of a liquid drop. Also what are the attractive forces that increase surface tension?
Chemistry news on Phys.org
The free energy is minimized by minimizing the surface area. For positive interfacial energy, that corresponds to a sphere (in the absence of gravity). For negative interfacial energy, that corresponds to mixing- *maximizing* the intrfacial area.
The atomic origins of interfacial energy are murky, to put it mildly. One need not discuss atoms to discuss dividing surfaces.
Depends on where the drop is - is it on a surface? Cohesion due to intermolecular attractions answers your second question it is your responsibility to find the list of such attractions.
yes it's on a surface
Then factor in adhesion-also research the topic of contact angle-the more the liquid molecule is attracted to the surface the less spherical it's going to be.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
