Discovering the Speed of Light: Michaelson-Morley Experiment and Variations
optrix
I've been looking at the Michaelson-Morley experiment for determining the speed of light using an interferometer, and managed to find a boxplot diagram on wiki, showing the results of a number of attemps. Now I'd like to see a setup and results from a similar experiment that takes the light from sources at different speeds, thus confirming that the speed of light is constsnt no matter what the speed of the source.
I suppose it is only a very slight modification to the Michaelson-Morley experiment, having sources at different speeds, and the results must be similar if the speed of light is indeed constsnt, but does this experiment go by a different name or is there any webpages that focus on this specifically?
Thanks
I think you may be missing the point: by orienting the device at different directions wrt the Earth's rotation and/or doing it at different times throughout the year, you can do the experiment many times, at many different speeds relative to the supposed fixed aether
It seems you want to make the light source move wrt the rest of the experimental apparatus. That wasn't the purpose of the experiment, but there are many practical devices that require such a setup, including the GPS system.
Ah ok I see your point thanks.
If you are interested in the magnitudes of change in GPS due to orbital velocities on one hand and the lower gravitational potential at satellite altitudes, you should be able to find data online. There are 'significant' corrections that must be made to maintain GPS accuracy to the roughly one meter range.
Thanks, but I'm only interested in (the experimental verification of) why the speed of light is constant. I thought the experiment arose from contradictions with Newtonian mechanics, i.e. for a light source moving 300m/s, the measured speed of light will be the same as for a stationary source, and so I thought that the speed of the source was varied w.r.t to measuring equipment. I'm not sure I fully understand the implications of the aether with this experiment actually.
Think of the aether like the air around you. If you are stationary and make a noise, the sound travels as a wave on the air, at about 750 mph. If you drive in a car at 50 mph, the speed of sound relative to the car is 700 mph forward and 800 mph backwards.
It seems like you are thinking of addition of velocity as if light were a particle. Ie, if you throw a baseball backwards at 50 mph from a car moving 50 mph, it drops straight down wrt a person standing on the ground. If you throw it forward, it moves at 100mph wrt a person on the ground. That isn't how light was believed to behave - light was believed to be a wave on a medium for the purpose of the MMX.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
