Load Inertia - Mass Moment of Inertia Question
The discussion centers on verifying a calculation for load inertia related to a motor driving three rollers at a 3.5:1 gear ratio. The calculated total inertia for the rollers is 67,155 lbm-in^2, converted to 19.65 kg-m^2, leading to a reflected inertia of 5.6 kg-m^2 after dividing by the gear ratio. However, a previous employee reported a value of 2.4 kg-m^2, prompting a request for clarification on the discrepancy. Another participant suggests that the reflected inertia should be calculated as load inertia divided by the square of the gear ratio, resulting in a value of 1.604 kg-m^2. The conversation highlights the importance of accurate calculations and considerations of safety factors in engineering assessments.
mselak500
I'm looking for some help to verify a calcualtion that was made by a previous employee.
The calcualtion was for load inetria (reflected to the motor). The motor will be driving (3) rollers at a gear ratio of 3.5:1 (motor turns 3.5 revolutions for every 1 revolution of the rolls).
I have a program that caluclates the mass moment of inertia for the rolls, and was able to verify this calucations with formulas that I found on the internet. The total inertia for all (3) rolls is 67,155 lbm-in^2. I converted this to 19.65 kg-m^2. If I divide this by the gear ratio of 3.5, I come up with 5.6 kg-m^2.
The previous employee came up with 2.4 kg-m^2.
Can someone help to tell me what I'm doing wrong.
Thanks,
I
Take a look below to see if any of these equations are useful. The reflected inertia is the (load inertia) / (gearing ratio^2).
I came up with 1.604 kg-m^2. Let me know if you want me to run it through my simulator. Note: I didn't include the gearing inertia - should be minor if you're using a belt system.
http://www.danahermotion.com/website/com/eng/download/document/sizinggearheads.pdf
I'm assuming the 50% saftey factor. Thanks much your all the help.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
