Rotational inertia of truck and trailer
To compute the energy required to accelerate a truck and trailer from 0 to 60 mph, both the mass and rotational inertia of the wheels and rims must be considered. The wheels can be approximated with an inertia of I = 0.8mR², and the kinetic energy contribution from the wheels is calculated as KE = (36/5)mv². This energy is added to the translational kinetic energy of the truck and trailer, resulting in a total kinetic energy formula of kE tot = (1/2)Mv² + (36/5)mv². The weight of the wheels is noted to be around 200 pounds for steel rims and 170 pounds for aluminum rims. Understanding these calculations is crucial for accurate energy assessments in vehicle dynamics.
CH_GR
I need to compute the energy to get a truck and trailer from 0 to 60 mph from rest taking into account the mass of truck and trailer and inertia of wheels and rims.
Do I treat the rims and tires as a cylindrical shell or solid cylinder? Once I find the energy of the tires and rims do I just add that to the 1/2MV^2 for truck and trailer?
thanks.
The moment of inertia of a cylindrical shell is mR2, while the solid cylinder is (1/2)mR2. The wheels are about 0.8mR2. For an automobile, the rolling tires add about 4% to the dynamic mass e.g., kinetic energy KE = (1/2)(1.04) mv2, where m is the static mass.
By wheel you mean tire and rim? Then I could use 0.8MR^2 to approximate the inertia instead of treating it separately as cylindrical shell and solid shell?
Does this approximation apply to all passenger car and truck tires?
thanks.
Yes, the tire and rim together are about I = 0.8 mR2. The 18 tires plus rims (=wheels) are only a small percentage (<5%) of total truck & trailer mass.
So the kinetic energy of a wheel is
KE = (1/2) I w2 = (1/2)(0.8)m (Rw)2 = (2/5) mv2 (rotational energy only)
For 18 wheels it is
KE = (36/5)mv2
This gets added to the total vehicle kinetic energy:
kE tot = (1/2)Mv2 + (36/5) mv2
How much do the wheels weigh (mg)? 200 pounds?
The wheels weigh 200 lbs for steel rims and 170 lbs for aluminum rims.
Thanks for the info.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
