Petit Einstein
- 8
- 0
How we can calculate the Miller's index?
Thanks
Thanks
turin said:It's a convention. There is something about the four different delimiters: (),[],{}, and <>. When you surround the numbers with (), then (102) is the same as (012), unless you are worried about the orientation. For the orientation's sake, you should have a right-handed permutation (conventionally) or you should specify.
Gokul43201 said:From the Bragg angle and the wavelength, you can get the inter-plane spacing, d.
n \lambda = 2d sin \theta~~
From the value of d, and the knowledge of the material (which tells you the lattice parameter, a) you can calculate the Miller Indices of the reflecting planes
d = \frac {a} {\sqrt{h^2+k^2+l^2}}
Dr Transport said:(020) and (022) are different planes of the same family
{220} = (220),(202),(022),(-220),(2-20),(-202),(20-2),(-2-20),(-20-2),(-20-2) etc...
Petit Einstein said:Ok i agree with u about this, but for exemple, the value of
{h^2+k^2+l^2} is equal to 8 so we will get the Miller index for example:
h=2; k=2 and l=0 or we write (220). if we want get (202) or (022) , are there possible?
Thank for your response.
