Vector product VS dot product in matrix
In summary: it will still be a matrix product. i presume one is cross (x) product , one is dot (.) product? or is it for matrix there is no such things as cross or dot product? that's weird. my tutor tells us to know the difference between cross and dot matrix productso for the case of the parallelpiped, what's the significance of the triple product (u x v) .w? why do we use x for u&v but . for w? is it just to tell us that we have to use sin and cos respectively? but if u v and w were square matrix, then there won't be any sin and cos to use? so we just multiply as
quietrain
655
hi, i don't really understand what's the difference between vector product and dot product in matrix form.
for example
(1 2) X (1 2)
(3 4) (3 4) = ?
so when i take rows multiply by columns, to get a 2x2 matrix, i am doing vector product?
so what then is dot producT?
lastly, my notes says |detT| = final area of basic box/ initial area of basic box
where detT = (Ti) x (Tj) . (Tk)
so, what's the difference between how i should work out x VS . ?
also, |detT| = magnitude of T right? so is there a formula i should use to find magnitude?
so why is |k . k| = 1?
thanks
for example
(1 2) X (1 2)
(3 4) (3 4) = ?
No, you are doing a "matrix product". There are no vectors here.
With matrices? It isn't anything. The matrix product is the only multiplication defined for matrices. The dot product is defined for vectors, not matrices.
Well, we don't have your notes so we have no idea what "T", "Ti", "Tj", "Tk" are nor do we know what a "basic box" is.
I do know that if you have a "parallelpiped" with adjacent sides given by the vectors [itex]\vec{u}[/itex], [itex]\vec{v}[/itex], and [itex]\vec{w}[/itex], then the volume (not area) of the parallelpiped is given by the "triple product", [itex](\vec{u}\times\vec{v})\cdot\vec{w}[/itex] which can be represented by determinant having the components of the vectors as rows. That has nothing at all to do with matrices.
No, "det" applies only to square arrays for which "magnitude" is not defined.
thanks
I guess you mean "k" to be the unit vector in the z direction in a three dimensional coordinate system. If so, then |k.k| is, by definition, the length of k which is, again by definition of "unit vector", 1.
You seem to be confusing a number of very different concepts. Go back and review.
oh.. em..
ok let's say we have
(1 2) x (4 5)
(3 4) (6 7) = so this is just rows multiply by column to get a 2x2 matrix right? so what is the difference if i replace the x sign with the dot sign now. do i still get the same?
is it just to tell us that we have to use sin and cos respectively? but if u v and w were square matrix, then there won't be any sin and cos to use? so we just multiply as usual rows by columns?
oh by definition . so that means |k.k| = (k)(k)cos(0) = (1)(1)cos(0) = 1
so |i.k| = (1)(1)cos(90) = 0 ?
so if i x k gives us -j by the right hand rule, then does it mean the magnitude, which is |i.k| = 0 is 0? in the direction of the -j?? or are they 2 totally different aspects?
btw, sry for another question,
why is e(w)(A),
where A =
(0 -1)
(1 0)
can be expressed as
( cosw -sinw)
( sinw cosw)
which is the rotational matrix anti-clockwise about the x-axis right?
thanks
quietrain said:
oh.. em..
(1 2) x (4 5)
You can replace it by whatever symbol you like. As long as your multiplication is "matrix multiplication" you will get the same result.
No, just changing the symbol doesn't make it one or the other.
I suspect your tutor was talking about vectors not matrices.
Because you are talking about vectors not matrices!
They are NOT matrices, they are vectors!
You can think of vectors as "row matrices" (n by 1) or "column matrices" (1 by n) but they still have properties that matrices in general do not have.
so |i.k| =(1)(1)cos(90) = 0 ?
Yes, that is correct.
No, the length of i x k is NOT |i.k|, it is [itex]|i||j|= 1[/itex].
In general, the length of [itex]\vec{u}\times\vec{v}[/itex] is [itex]|u||v| sin(\theta)[/itex] where [itex]\theta[/itex] is the angle between [itex]\vec{u}[/itex] and [itex]\vec{v}[/itex].
why is e(w)(A),
where A =
(0 -1)
(1 0)
can be expressed as
( cosw -sinw)
( sinw cosw)
thanks
For objects other than numbers, where we have a notion of addition and multiplication, we define higher functions by using their "Taylor series", power series that are equal to the functions. In particular, [itex]e^x= 1+ x+ (1/2)x^2+ \cdot\cdot\cdot+ (1/n!)x^n+ \cdot\cdot\cdot[/itex].
It should be easy to calculate that
[tex]A^2= \begin{pmatrix}-1 & 0 \\ 0 & -1\end{pmatrix}[/tex]
[tex]A^3= \begin{pmatrix}0 & 1 \\ -1 & 0\end{pmatrix}[/tex]
and, since that is the identity matrix, it all repeats:
[tex]A^4= \begin{pmatrix}0 & -1 \\ 1 & 0}\end{pmatrix}= A[/tex]
etc.
That gives
[tex]e^{Aw}= \begin{pmatrix}1 & 0 \\ 0 & 1\end{pmatrix}+ \begin{pmatrix}0 & -w \\ w & 0\end{pmatrix}+ \frac{1}{2}\begin{pmatrix}-w^2 & 0 \\ 0 & -w^2\end{pmatrix}[/tex][tex]+ \frac{1}{3!}\begin{pmatrix}0 & w^3 \\ -w^3 & 0\end{pmatrix}+ \frac{1}{4!}\begin{pmatrix}w^4 & 0 \\ 0 & w^4\end{pmatrix}+ \cdot\cdot\cdot[/tex]
[tex]= \begin{pmatrix}1- \frac{1}{2}w^2+ \frac{1}{4}w^4+ \cdot\cdot\cdot & -w+ \frac{1}{3!} w^3+ \cdot\cdot\cdot \\ w- \frac{1}{3!}w^3+ \cdot\cdot\cdot & -1+ \frac{1}{2}w^2- \frac{1}{4}w^4+ \cdot\cdot\cdot\end{pmatrix}[/tex]
and you should be able to recognise those as the Taylor's series about 0 for cos(w) and sin(w).
wow.
ok, i went to check again what my tutor said and it was
"scalar and vector products in terms of matrices". so what does he mean by this?
the scalar product is (A B C) x (D E F)T, (so we can take the transpose of DEF because it is symmetric matrix? or is it for some other reason? )
so rows multiply by columns again?
but what about vector product?
for the parallelpiped, (u x v).w
so let's say u = (1,1) , v = (2,2), w = (3,3)
so u x v = (1x2, 1x2)sin(angle between vectors)
so .w = (2x3,2x3) cos(angle) ?
so if it yields 0, that vector w lies in the plane define by u and v, but if its otherwise, then w doesn't lie in the plane of u v ? for i x k, why is the length |i||j|? why is j introduced here? shouldn't it be |i||k|sin(90) = 1?
oh i see.. so the right hand rule gives the direection but the magnitude for i x k = |i||k|sin(90) = 1?
thanks a ton!
quietrain said:
wow.
Okay, you think of one vector as a row matrix and the other as a column matrix then the "dot product" is the matrix product
[tex]\begin{bmatrix}A & B & C\end{bmatrix}\begin{bmatrix}D \\ E \\ F\end{bmatrix}= AD+ BE+ CF[/tex]
But the dot product is commutative isn't it? Does it really make sense to treat the two vectors as different kinds of matrices? It is really better here to think of this not as the product of two vectors but a vector in a vector space and functional in the dual space.
Yes, that was a typo. I meant |i||k|.
Yes.
thanks a ton!
i see. thank you very much
Related to Vector product VS dot product in matrix
What is the difference between vector product and dot product in a matrix?
The vector product, also known as the cross product, is a binary operation on two vectors in three-dimensional space. It results in a vector that is perpendicular to both of the original vectors. The dot product, on the other hand, is a scalar (single value) that is calculated by multiplying the corresponding components of two vectors and adding them together.
What are the mathematical formulas for vector product and dot product in a matrix?
The vector product is calculated by taking the determinant of a 3x3 matrix made up of the two vectors and their unit vectors in the x, y, and z directions. The dot product is calculated by multiplying the corresponding components of the two vectors and adding them together.
In what situations would you use vector product versus dot product in a matrix?
The vector product is often used in physics and engineering to calculate torque, angular momentum, and magnetic fields. The dot product is used in geometry to calculate the angle between two vectors, and in physics to calculate work and energy.
What are some applications of vector product and dot product in a matrix?
The vector product is used in computer graphics and 3D modeling to calculate the orientation of objects and to create realistic lighting effects. The dot product is used in machine learning and data analysis to calculate the similarity between two vectors and to find patterns in data.
Are there any real-world examples that illustrate the difference between vector product and dot product in a matrix?
One example is the calculation of torque and angular momentum in physics. Torque, which causes rotational motion, is calculated using the vector product, while angular momentum, which is a measure of rotational motion, is calculated using the dot product.
  • Linear and Abstract Algebra
  • Calculus
