What factors affect the rotating speed of a motor?
The speed of a motor is influenced by its type and the frequency of the power supply, as described by the equation Ns = 120f/p, which applies primarily to AC induction motors. While this equation suggests a maximum speed of 3600 RPM for a 2-pole motor at 60 Hz, many tools, such as woodworking routers, exceed this speed due to the use of universal motors or other mechanisms like frequency converters and gearing systems. Universal motors and DC brush commutated motors do not adhere to the same speed limitations as AC induction motors. Understanding the specific motor type and its operational characteristics is crucial for determining its speed capabilities. Overall, various factors, including motor design and power supply frequency, significantly affect motor rotation speeds.
mainer0311
This is my first post, so I'll give a bit of an intro. I am an marine engineering cadet at mass maritime academy in my junior yet. I took physics II last semester and this semester I am taking electrical machines.
In class today we were talking about how fast motors can rotate and came up with this equation:
Ns = 120f/p Ns being the speed of the motor, f being the frequency and p being the number of poles.
with this equation using 60hz and a 2 pole motor it says that a motor will only rotate at 3600 rpm's.
I know this isn't true because wood working routers rotate well over 15,000 rpm.
I asked my Proff how this worked and was told to try and find an answer for next class.
I haven't been able to find anything searching google about it. Does anybody know how this works?
Thanks Cooper
Different types of motors have different speed and torque characteristics.
The equation applies to AC induction motors, which run asynchronously at just under that suggested. It also applies to some synchronous motors.
Universal motors, DC brush commutated motors and many others do not obey the equation.
So the speed of an induction motor is dependent on the frequency of the power going to it?
And these tools that require speeds greater then 3600 rpm use a universal motor?
this is making more sense, thanks.
Or a frequency converter. Or gears and pulleys. It all depends on the system being powered.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
