Connect 3.55mm Leads w/o Solder: Male TRS Connector
  • Thread starter Thread starter geoduck
To connect leads to a male TRS connector without soldering, users can look for in-line male 3.5 mm stereo plugs that allow for screw connections. These connectors can be found at electronics stores like Radio Shack or local hobby shops. While soldering is typically recommended for a secure connection, solderless options are available, albeit often at a higher cost. It's essential to ensure that the connector is compatible with the circuit leads being used. For those unfamiliar with soldering, exploring solderless alternatives is a practical solution.
geoduck
I need to connect the leads of a circuit to a male TRS connector (3.55 mm). How would I do this? When I go to the store, all I see are male-male 3.55 mm connectors, which would mean I would have to solder the ends of the circuit to one of the male ends, which seems awkward.
Is there an easier way to do this, preferably without the need for solder? Is there a 3.55 mm connector that is male-to-wires, where you can just attach your three wires to the connector, and then plug the male into whatever device you want which would connect the three wires to the device via the male?
You should be able to find in-line male 3.5 mm stereo plugs that allow you to solder some pig-tails on. If you're in the States, you should still be able to get these at Radio Shack. Better place to go would be your local electronics hobby shop, however. I'd put on a little heat shrink (available at the above-mentioned places, or any automotive / hardware supply store) over top of the soldered connection to keep things from shorting out.
I hope I'm not patronizing here, but if you're using a soldering gun or high powered iron, you should buy / borrow a more suitable soldering iron.
Thanks. You're not patronizing - I'm utterly clueless when it comes to electronics (and don't know how to solder or own a soldering iron). I was able to find a solderless plug, one that used screws, but it was a bit more expensive because it was gold-plated. It's here:
http://www.radioshack.com/product/index.jsp?productId=2103990
Obviously someone who was competent would just buy a cheaper plug and use solder, but because of my deficiencies I was looking for a very specific product.
Thanks.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
