Selection rules electrostatic field
pstq
Hi all , I need some help with this problem,
A hydrogen atom, which is in its ground state |1 0 0 > , is put into a weak time-dependent external electric field, which points into the z direction:
\boldsymbol{E}(t,\boldsymbol{r}) = \frac{C\hat{\text{e}}_{z}}{t^{2}+\tau ^{2}}, where C and \tau > 0 and e are constants. This gives rise to a perturbation potential V(t) = C\frac{e\hat{z}}{t^{2}+\tau^{2}}.
Using lowest-order time-dependent perturbation theory, find the selection rules for transitions from the ground state, i.e. find out which final state values for the quantum numbers n, l and m are possible in transitions from the ground state.
P_{fi}(t,t_{0})\equiv |\langle\phi_{f}|\psi(t)\rangle|^{2}\approx \frac{1}{\hbar^{2}}\left|\int_{t_{0}}^{t}\text{d}t _{1}\langle\phi_{f}|V_{S}(t_{1})|\phi_{i}\rangle \text{e}^{\text{i}(E_{f}-E_{i})t_{1}/\hbar}\right|^{2}.
First, I have to see the values of m for which the sandwich vanish i.e. < n l m| \hat{z} | 1 0 0 > =0
< n l m| \hat{z} | 1 0 0 > = I (radial ) χ \int Y^*_{l,m} Cos [\theta]d \Omega Y_{0,0}
The radial part is always non zero,
Therefore , i have to compute
\int d \Omega Y^*_{l,m} \cos (\theta) Y_{0,0} = But I don't know what I can use, to compute the terms \cos (\theta) X spherical harmonics
thanks for your help!
Hint: Look up Y1,0.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
