Proving Ceva's Theorem with Triangle PQR
  • Context: Undergrad
  • Thread starter Thread starter tomz
    Theorem Triangle
The discussion focuses on proving Ceva's Theorem in the context of triangle PQR, where tangents to the inscribed circle touch the circle at points A, B, and C. The theorem states that lines PA, QB, and RC are concurrent if the product of the ratios of the segments they create is equal to one. The user mentions using Geometry Sketch Pad to visualize the problem and notes that the parallel lines form a congruent triangle rotated 180 degrees, which aids in understanding the concurrency of the lines.
  • Understanding of Ceva's Theorem
  • Familiarity with triangle geometry
  • Knowledge of inscribed circles and tangents
  • Experience with Geometry Sketch Pad
  • Study the proof of Ceva's Theorem in detail
  • Explore the properties of inscribed circles in triangles
  • Learn how to use Geometry Sketch Pad for geometric proofs
  • Investigate the concept of triangle congruence and its applications
Mathematicians, geometry enthusiasts, students studying triangle properties, and educators looking to teach advanced geometric concepts.
tomz
I have tried but still cannot get it. Simple geometry question.
Tangents to the inscribed circle of triangle PQR are parallel to [QR], [RP] and [PQ]
respectively and they touch the circle at A, B and C.
Prove that [PA], [QB] and [RC] are concurrent
relevant formula:
Ceva's theorem (Any three concurrent lines drawn from the vertices of a triangle divide the sides (produced if necessary) so that the product of their respective ratios is unity/
Thank you in advance!
I have tried on geometry sketch pad. It did works...
some thoughts: The parallel lines form a triangle congruent to the first rotated 180 degrees. The tangents of both triangles have a corresponding point 180 degrees apart on the circle.
  • Poll Poll
