Gauss's law intuitive explanation?
Gauss's law states that the electric flux through a closed surface is proportional to the enclosed electric charge, which helps in determining electric fields in specific regions. When applying Gauss's law, if a Gaussian surface does not enclose any charge, the net electric flux is zero, indicating that the electric field in that region can still exist but is not determined by the enclosed charge. The law essentially reflects the conservation of energy for electric fields, showing that the electric field strength decreases with distance from a point charge. Understanding Gauss's law is crucial for analyzing electric fields, as it allows for the calculation of fields based on the charge distribution within a defined surface. Overall, Gauss's law is a fundamental principle in electrostatics that connects charge and electric field behavior.
lord_james
I'm not sure what Gauss's law really means. "The electric flux through any closed surface is proportional to the enclosed electric charge." How does this apply to finding the electric field?
apcentral.collegeboard. com/apc/public/repository/ap11_frq_physics_cem.pdf
Look at parts 1 a and b. Part 1a is easy enough to do, but I want to really understand why Gauss's law applies here. collegeboard. com/apc/public/repository/ap11_physics_c_electricity_magnetism_scoring_guidelines.pdf
Here are their solutions. (Remove the space before com in both links). The fact that the enclosed charge is zero does not tell you anything about the electric field, though, as evidenced by part (b). What if I draw a Gaussian surface next to, but not enclosing, a point charge? There is no enclosed charge, and no net flux, but there is still obviously an electric field. So why do they want Gauss's law used in these situations?
Gauss' Law in it's mathematical form is \oint\vec E \cdot \vec {da} = \dfrac{1}{\epsilon _o}Q_{enc}. If we draw a Gaussian surface encompassing the region in which we seek to determine the electric field, the left side of the equation 'picks out' the all sources in this region, and says that the electric field is proportional to the charge enclosed only in this region we've defined with our Gaussian surface, which is the right side of the equation. Notice that in regions that no charge is enclosed, the left side of the equation is zero because all flux entering a Gaussian surface leaves the surface as well.
In reference to your statement about the enclosed charge equaling zero telling you nothing about the \vec E field, that's false. It tells you that \vec E = 0. Gauss' Law allows you to determine electric fields for regions. If you want to know the field in a particular region, the Gaussian surface must enclose that region, and the charge generating the field.
lord_james said:
I'm not sure what Gauss's law really means. <snip>
Gauss's law is a form of conservation of energy for a field. For example, we say that a charge generates an electric field. If you enclose the charge with a spherical surface, the electric field at the surface is Q/r^2. No matter what radius you choose, the total field 4πr^2*Q/r^2 through the surface is constant.
Conceptually, Gauss's law in electrostatics states that electric charges create electric fields, magnetic charges create magnetic fields (and since there are no magnetic charges, div(B) = 0). Gauss's law (in other contexts) means the intensity of light from a point source falls off quadratically with distance, the gravitational field of a point source falls off quadratically with distance, etc. etc.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
