How Does Gauss' Law Apply to Gravitational Fields?
Gauss' Law for gravitational fields states that the gravitational flux through a closed surface is proportional to the enclosed mass, expressed as Φ = -4πGM. To find the gravitational acceleration at a distance of R/2 from the center of a planet, one must consider that the mass within this radius is one-eighth of the total mass due to uniform density. The calculations initially led to confusion regarding the correct value of gravitational acceleration, with one participant arriving at -17.4 m/s², which was incorrect. After clarifying the mass and volume relationships, the correct gravitational acceleration was determined to be approximately 4.35 m/s², confirming that the negative sign indicates the direction of the field towards the center of the planet. This discussion highlights the application of Gauss' Law in gravitational contexts and the importance of understanding mass distribution within spherical bodies.
arl146
The gravitational field g due to a point mass M may be obtained by analogy with the electric field by writing an expression for the gravitational force on a test mass, and dividing by the magnitude of the test mass, m. Show that Gauss' law for the gravitational field reads:
\Phi = \oint g\bullet dA = -4*pi*G*M
Use this result to calculate the gravitational acceleration g at a distance of R/2 from the center of a planet of radius R = 8.05 × 10^6 m and M = 8.45 × 10^24 kg.
above equation
i can't get the answer right for this .. here's what i did
g\oint dA = -4*pi*GM
g[4*pi*r^2] = -4*pi*GM
g[4*pi*(R/2)^2] = -4*pi*GM
g*pi*R^2 = -4*pi*GM
g = (-4GM)/R^2
and since r=R/2 the mass is halved also. therefore g = (-2*G*M)/R^2
i plugged in the values for G, M, and R .. and got -17.40267737 m/s^2 but its not right
anybody can give any hints of what I am doing wrong?
Are you sure about that? :wink:
(What percentage of the sphere's volume--and thus mass, assuming uniform density--is located at r < R/2?)
ummm .. is the mass 1/8 of M? since V= (4/3)*pi*r^3
and since R=r/2 ... that makes it V = (4/3)*pi*(R^3/8)
meaning the volume is 1/8 of the total. and since D = M/V ---> M=DV so the mass also is 1/8 of the original?
Assuming that the density of the planet is uniform, yes, that's correct.
is g supposed to be negative? also i got 4.3506693 m/s^2 is that right can someone check for me?
Likes Rahul69512
That looks good. g is negative just means that the field points toward the center.
ok i got it that makes sense. thanks!
