It's basically voodoo in 7 dimensions. What people need is the wedge product, not the cross product, and an understanding of dealing with bivectors and other such objects.
It is really, really easy to geometry on objects that don't go through the origin using projective geometry. Consider a 2d space, spanned by basis vectors e_1, e_2. Add one extra dimension with basis vector e_0. The plane that is 1 unit from the origin in the e_0 direction is taken to be the real 2d plane.
The convenience of this geometry is that lines in our real 2d plane that don't go through the origin can be thought of as the intersections of 2d subspaces with our real 2d plane. Given two points on our real 2d plane p and q, the real line containing them is L = p \wedge q, and the shortest distance from that line to the origin is e_0 \cdot (e_0 \wedge L).
There are a lot of symbols here that might not be understood, so let me give an example. Let L be the line through x=1, y=0 and x=0, y=1. By simple geometry, we know that the distance from the origin to this line is 1/\sqrt{2}. Let's verify that with projective geometry.
Let p = e_0 + e_1 and q = e_0 + e_2. The line L is then p \wedge q = e_0 \wedge e_2 + e_1 \wedge e_0 = e_{02} + e_{10} + e_{12}. First, we find the volume that the 2d subspace makes with e_0. To do this, we just wedge in another e_0 on the front:
e_0 \wedge L = e_0 \wedge (e_{02} + e_{10} + e_{12} = e_{012}
And then we find the part of this volume that is perpendicular to e_0. This gives us the "footprint" or "shadow" of the 2d subspace on the real 2d plane. This quantity is called the "moment" M of the line.
M = e_0 \cdot (e_0 \wedge L) = e_{12}
Now, we also need the direction of the line, which is found by a = e_0 \cdot L = e_0 \cdot (e_{02} + e_{10} + e_{12})= e_2 - e_1 + 0. We need this because the moment is made up of two parts: the direction a and a support vector d--which is the vector to the closest point, which is what we're interested in. We just multiply the moment M by a on the right to help extract d. More specifically, we're going to multiply by a^{-1} \equiv a/a^2 on the right:
d = Ma^{-1} =e_{12} (e_2 - e_1)/2 = (e_1 + e_2)/2
The length of this vector is clearly \sqrt{2}/2, and we've found not only the distance but the vector to this point. You probably already know that vector if you have the equation of the line, but here we've found it just by starting with two points on the line.
We can extend this to arbitrary dimensions because the wedge product (and all of the generalized products used here) is valid in such spaces, where the cross product is not. So we just need the following:
\begin{align*}M &= e_0 \cdot (e_0 \wedge L) \\<br />
a &= e_0 \cdot L \\<br />
d &= Ma^{-1}<br />
\end{align*}
And that's it. This works in any number of dimensions. The projective geometry does introduce a little more overhead and may be a little harder to visualize, but it makes the process of finding the distance to a line (and indeed, to a plane or beyond) very mechanical.
This gives the distance from a line to the origin; translation should be enough to find the distance to an arbitrary point.
(You can also find the line L with a point on the line and a direction also. Everything else follows from that.)
