The photon and em wave models are both drilled into students - I'm wondering if the links need to be clearer earlier?
Light intensity is number of photons per unit area per unit time?
I think "
light intensity" and "
light flux" are terms that could mean just about anything.
The "
photon flux" is the number of photons through a unit area per unit time.
- which seems to be what is intended here by "light flux". The word "light" has a range of uses in physics as well as regular language. I suspect that sophiecentaur is probably on to something by insisting on a precise language here.
The "intensity of the light wave" would be the square of the amplitude of it's electric field? (sophiecentaur?) ... which would be related to the photon flux
and the photon energy. (Photons are understood primarily as energy quanta ... though wavelength, momentum etc can also be used to characterize a photon.)
The "luminous intensity" of a light source would be the power per unit solid angle being emitted by a light source. So already, two different ways to define "intensity of light".
"brightness" is a subjective measure that means different things in different circumstances. In common language, we would understand one object to be brighter than another is it appears to glow more when you look at it. This is what I've been trying to talk about on the first page of this thread.
Some examples:
(1)Some colors look brighter than other colors (part of the original question) because they look more like the colors in fire - for example - so the common concept is to do with more that just the light itself.
(2)stars with a high visual magnitude will look brighter than those with a low visual magnitude. Originally the visual magnitude was a subjective measure related to the way the human eye perceives light. However, astronomy has objective ways to assign magnitude to stars (look this up for more). Astronomers may refer to "bright stars" informally, in this context.
(3) photographers may refer to brightness in terms of the tendency of part of the picture to wash out other parts ... they use a light meter to help them work out exposure times. The meter usually measures power per unit area, averaged across the detection surface and this can be called the "brightness of the light" but more likely it will be called the "light level". I have seen "light flux" used in old SLR camera manuals.
(4)Drakkith seems to be using "brightness" to mean the number of photons emitted, per unit solid angle, from a light source (Drakkith?)
[edit] in order to be consistent with the linked article (earlier)
Because of the very wide usage, it is possible to come up with a reasonable sounding definition of "brightness" to contradict pretty much any argument. The term should be understood only in the context of a particular description. I don't think it is useful as a concrete general term.
I suspect that the persistence of OPs confusion in the face of repeated answers may indicate that we have yet to identify it's source. Perhaps sorting out more rigorous terms
will help?
