Thinking more about the original question
Soaring Crane said:
If the p-value increases, then we are more likely to retain the null, and doesn't this increase Type II error?
I've tried to defog my mind as follows:
Suppose we define an interval such as I_A = {-1.5,1.5}.
And suppose we sign some contracts such as the following:
If the sample mean falls in I_A then I will dance a jig.
If the sample mean falls in I_A then I will accept the teaching of the philosopher Hegel
If the sample mean falls in I_A then I will reject the theory of Evolution
Now define a larger interval I_B = {-2.0, 2.0}.
What can we say about analagous contracts that are based on I_B instead of I_A?
A contract such as
If the sample mean falls in I_B then I will dance a jig
is at least as likely to take effect as the similar contract based on I_A since I_B includes I_A as a subset. The contract based on I_B will be more likely to take effect if increasing the interval to I_B includes an additional event that has positive probability.
If we restrict ourselves to situations not mentioned in the contract, such as particular weather, the same conclusions apply. The contract about dancing a jig didn't mention anything about the weather. So we can say:
If it is raining then the probability that I will dance a jig under the contract using I_B is equal or greater than the probability that I will dance a jig under the contract using I_A.
The contracts don't mention any conditions about the absolute truth of the ideas to be accepted or rejected. Thus we can say:
If the ideas of Hegel are false then the probability that I will dance a jig under the contract using I_B is equal or greater than the probability that I will dance a jig under the contract using I_A.
and
If the ideas of Hegel are false then the probability that I will accept the teaching of the philosopher Hegel under the contract using I_B is equal or greater than the probability that I will accept his teaching under the contract using I_A.
and
If the ideas of Hegel are true then the probability that I will accept the teaching of the philosopher Hegel under the contract using I_B is equal or greater than the probability that I will accept his teaching under the contract using I_A.
and
If the theory of evolution is false then the probability that I will accept the teaching of the philosopher Hegel under the contract using I_B is equal or greater than the probability that I will accept his teaching under the contract using I_A.
and
If the theory of evolution is false then the probabtility that I will reject the theory of Evolution under the contract using I_B is equal or greater than the probability that I will reject it under the contract using I_A.
If the theory of evolution is true then the probabtility that I will reject the theory of Evolution under the contract using I_B is equal or greater than the probability that I will reject it under the contract using I_A.
The answer to original question is that the probability of type II error will increase if you enlarge the acceptance interval and the enlargement includes some event with non-zero probability. But, more generally, the probability of your doing anything ( dancing a jig, etc.) that is triggered by the result falling in a certain region will increase if you enlarge the region to include addtional probability.
