Solving Equations with the Lambert W Function: A* (e^2x - e^x) + b*x = c
  • Thread starter Thread starter jya
The discussion centers on solving the equation a*(e^(2x) - e^x) + b*x = c using the Lambert W function. It is established that the equation can be reformulated to find the intersection of a line with a quadratic in e^x. Specifically, the transformation leads to the equation e^x(e^x - 1) = mx + k, where m and k are derived from the parameters a, b, and c. Participants express interest in determining x directly from the values of a, b, and c without graphing. The conversation emphasizes the potential for special functions to facilitate this solution.
jya
I know we can solve e^x=x by the Lambert W function, but is it possible to solve the following equation:
a*(e^(2x)-e^x)+b*x=c
in terms of a, b, and c.
Mathematics news on Phys.org
Welcome to PF;
solve: a*(e^(2x)-e^x)+b*x=c ... in terms of a, b, and c.
Solving for x given a,b,c you mean? That would be the intersection of a line with a quadratic in e^x... that is $$ e^{x}\left ( e^x - 1\right ) = mx+k$$ ...where ##m=-b/a## and ##k=c/a##.
And you want to find x given m and k.
That help?
Thank you Simon. Yes. I am wondering if there is some special function can solve this problem, i.e. given the values of a,b,c (or m,k in your equation) I can find out the value of x without looking at the graph.
Simon Bridge said:
Welcome to PF;
That help?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
