| Thread Closed |
gravity anomaly during solar eclipse. |
Share Thread | Thread Tools |
| Jul28-09, 05:52 AM | #1 |
Hi all,
http://www.newscientist.com/article/...y-anomaly.html the link given above elucidates that the gravity falls during the solar eclipse. I could not understand the logic. Can some one help me in understating the reason for this? why such discrepancy happens only during the solar eclipse why not during the new moon…. If duing the solar eclipse gravity falls then will there be an increase in gravity duing lunar eclipse? |
| Jul28-09, 09:00 AM | #2 |
| Jul28-09, 10:21 AM | #3 |
Well I never told that there is an answer for the anomalies…. This paper just tells that the there is anomalies. I wanted to know why? as it is against my conventional thinking as I see g=Me/r^2
This leaves me that g should be constant and should not vary with eclipse. |
| Jul28-09, 12:50 PM | #4 |
| Jul29-09, 12:12 AM | #5 |
I wanted to write gravity is proportional to mass of earth and inversely proportional to square of its radius. |
| Jul29-09, 10:49 AM | #6 |
[tex]F=\frac{GM_{e}M_{o}}{R^2}[/tex] G is universal constant Me = Mass of earth Mo = Mass of object R = Distance BETWEEN both objects as measured from centre to centre The GPE equation is similar only its referenced differently. So it is all negative and it is divided by just the distance between objects not the squared distance. |
| Jul29-09, 11:43 AM | #7 |
You have a small force vector from the moon's gravity. You should experience nearly the same effect if the moon was nearly in the same direction of the sun from earth, but not necessarily eclipsing.
This wouldn't explain the phenomena in the article though. You should just be a bit lighter that day. |
| Jul30-09, 01:50 AM | #8 |
One of the article claims it is less by ~8x10^-8 cm/s^2 ; but it will not match up right? Or have I missed some thing….. |
| Jul30-09, 05:55 AM | #9 |
I don't know what the numbers are on this - it's just a thought. Is it possible that the sun's gravitational waves are rippling around the moon resulting in positive and negative wave reinforcement such that it is only strong enough to be observable when you are directly behind the moon with respect to the sun and at just the right distance from the moon?
| Jul30-09, 06:21 AM | #10 |
Mentor
| Jul30-09, 07:01 AM | #11 |
| Jul30-09, 04:15 PM | #12 |
| Jul30-09, 04:17 PM | #13 |
F=ma=GMm/r^2 gmoon = GM/r^2 G = grav constant M = Moon mass r = radius of moon's orbit minus earth's radius. I'll plug and chug |
| Jul30-09, 04:25 PM | #14 |
I get 3.8 EE-5 ms^-2, so that's about the same as the number above. They might have used perigee vs apogee.
That's about 4 millionth's of g. So basically nothing. |
| Jul30-09, 11:19 PM | #15 |
I doubt the answer is so straight forward. Please look at some of the conventional explanations of anomalous observations during solar eclipses. If u think that force of moon has changed the gravity on earth why is that gravity did not increase during lunar eclipse? |
| Jul30-09, 11:32 PM | #16 |
Without having read the article, is the measured error induced by wishful thinking diminutive to systemic error?
-but perhaps my question should reside in the social science folder. |
| Jul30-09, 11:35 PM | #17 |
Its an old wives tale, nothing gravitationally exceptional occurs during an eclipse. The paper you cite is . . . suspect.
| Thread Closed |
| Thread Tools | |
Similar Threads for: gravity anomaly during solar eclipse.
| Thread | Forum | Replies | ||
| Total solar eclipse | General Astronomy | 4 | ||
| Eclipse between solar planets | General Astronomy | 2 | ||
| During a solar eclipse....calculate forces.......etc | Introductory Physics Homework | 11 | ||
| huyghen's principle & solar eclipse | General Physics | 0 | ||
| Solar Eclipse | General Astronomy | 1 | ||
