Thread Closed
Double Slit Diffraction
Share Thread
Jan5-10, 10:28 AM   #1
1. The problem statement, all variables and given/known data
A parallel beam of mono-chromatic light (500nm) is incident on 2 long narrow slits: slit width is 0.1mm and the distance between slit centres is 0.3mm.
a) How many bright fringes cover the central diffraction maximum?
2. Relevant equations
Condition for constructive interference:
[tex]\Delta = 2d.cos\theta = 2m(\lambda\div2)[/tex]
Reduces to:
[tex]2d=m\lambda[/tex] as [tex] cos\theta=1[/tex] ?
3. The attempt at a solution
I get 1200 once I convert both[tex] d [/tex]and [tex]\lambda[/tex] into metres. Is this the right thing to do? I'm not sure this is the amount that cover the central maximum, what does this bit mean?
- - - Part b)
Part b) Calculate the angle corresponding to the first diffraction minima
[tex]sin\theta= ((2m-1)\lambda)\div2)\div d [/tex]
Taking m as 1 because it is the first diffraction minima
Reduces to:
[tex]\theta = arcsin[ (5\times10^{-7}) / (6\times10^{-4}) ][/tex]
I get [tex]\theta[/tex] = 0.048 degrees
is this correct?
There is part c) but haven't attempted it yet, overall the whole question is allocated 14 marks.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan7-10, 08:46 AM   #2
we need to find the range of the diffraction central bright band first by using 1st minima condition a sin theta= lambda(m=1 for first minima) and a=slit width
then we determine the condition for interferance maxima (in the same angular range)by using d sin theta= m lambda where d= distance between two slits,m= 1,2,3...... for the right half.
dividing these 2 equations , we will get m which will indicate the number of interferance bright bands within the first diffraction band ON ONE SIDE ONLY.
remember that we still need to add the left half and the central bright interferance band.
in general , the number of bright bands will be 2m+1.
Thread Closed
Tags
diffraction, fringes, maximum, minimum, slits
Similar discussions for: Double Slit Diffraction
Thread Forum Replies
Electron double slit diffraction with unequal widths Introductory Physics Homework 3
KE of Electrons to give same theta as light in double slit diffraction Advanced Physics Homework 4
Uncertainty in Double-Slit Diffraction Advanced Physics Homework 0
Young's Double Slit vs. Diffraction grating Introductory Physics Homework 1
Double Slit Diffraction Problem Introductory Physics Homework 2
