Thread Closed
Conductors and Inductors?
Share Thread Thread Tools
May30-10, 06:24 PM   #1
Can all conductors be inductors and could all inductors be conductors?
I get confused about this because I know that inductor can be positively charges by a conductor. Can an conductor become an inductor by losing its charge from an inductor?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
May31-10, 12:12 AM   #2
Recognitions:
Gold Membership Gold Member
I would say, outside of an external means (say temperature) to change the chemistry or physical properties of a material, that a conductor cannot be an insulator and vice-versa. The two materials are exclusively defined. A conductor is a material where the electrons have no barriers from moving from the valence band to the conduction band and are more or less free to move about the material. An insulator is a material that has a significant barrier between the energies of the valence electrons and those of the closest conduction band levels. A semiconductor has properties of both in that there is still a bandgap (a series of energy levels between the valence and conduction bands that electrons cannot exist at), but the bandgap is small enough that we can excite electrons from the valence to the conduction band by injecting sufficient energy into them.
May31-10, 12:20 AM   #3
All conductors are posess inductance without exception.
May31-10, 12:33 AM   #4
Recognitions:
Quote by Antiphon View Post
I don't think he means inductance and capacitance, but insulator and conductor in terms of the chemical (and atomic) properties of the material.
May31-10, 01:30 AM   #5
Ok, how about: All real wires irrespective of their their chemical and atomic properties as long as they conduct electric current are inductors.
What am I missing?
May31-10, 02:06 AM   #6
Recognitions:
What am I missing?
$#&!%@. I think he means INSULATOR and conductor, I got caught up with the word "inductor" that he was using. Going off his positive and negative charges statements, I assumed that he was talking about conductors and insulators where you can strip off the electrons of an insulator to make it positively charged and negatively charge a conductor. Don't know why I kept using his word "inductor." Otherwise his statement about charges does not make sense in terms of inductance and conductance. I'll change my previous posts to reflect this.
May31-10, 02:55 PM   #7
So from what I understand is that conductors and inductors are constantly
switching. Is this correct?
May31-10, 03:16 PM   #8
Quote by mapa View Post
No mapa. You mean insulator not inductor. Inductor means something completely different.
And no they aren't usually changing.
May31-10, 05:00 PM   #9
Every conductor has inductance. It doesn't switch from being a conductor and being an inductor, inductance just comes with conducting current. An inductor is just a conductor shaped to exaggerate the inductance...a wire wound in a coil. Inductors are not charged, either positively or negatively.
If you mean insulator instead of inductor, then in a substance is either a conductor or an insulator, materials generally don't switch between the two. If enough voltage is applied, an insulator will conduct current, but this generally destroys the insulator.
Charge isn't involved here the way you were describing either...insulators and conductors are both normally electrically neutral, but can be positively or negatively charged. Charge doesn't make something an insulator or a conductor. (or an inductor)
Thread Closed
Thread Tools
Similar Threads for: Conductors and Inductors?
Thread Forum Replies
Inductors: what do they do? Introductory Physics Homework 11
A circuit comprises an inductor of 700mH of negligible resistance Engineering, Comp Sci, & Technology Homework 17
More on inductors Electrical Engineering 3
Inductors Engineering, Comp Sci, & Technology Homework 2
Inductors Electrical Engineering 0
