New Reply
Horizontal projectile, NOT GIVEN INITIAL VELOCITY
Share Thread Thread Tools
Feb21-12, 05:43 PM   #1
1. The problem statement, all variables and given/known data
A cannon ball is fired horizontally off the top of a cliff that is
400 m high above the ocean. The ball hits the water 600 m
away. With what speed does the cannon ball enter the water?
2. Relevant equations
I've tried using
d[itex]_{x}[/itex] = u[itex]_{x}[/itex]*t
d[itex]_{y}[/itex] = u[itex]_{y}[/itex]*t + 1/2a[itex]_{y}[/itex]*t[itex]^{2}[/itex]
and also solving for t
t = [itex]\sqrt{2y/g}[/itex]
3. The attempt at a solution
So I found that t = 9 seconds
and that u[itex]_{x}[/itex] = 66.4
but i can't seem to figure out how to find final velocity, or speed.
I know what the correct answer is (111 m/s), I just can't figure out how it was gotten.
I have an exam in an hour, any help would be greatly appreciated!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb21-12, 06:08 PM   #2
Mentor
You found the horizontal component of velocity, now find the vertical component. Once you have both components, you can figure out the total speed.
Feb21-12, 06:14 PM   #3
u[itex]_{y}[/itex] = 22.6
so if i do square root of 66.4^2 + 22.6^2 I should get my answer but i get 70.1 instead.
how do you find the final based on the x and y components?
Feb21-12, 06:17 PM   #4
Mentor
Quote by xannaxiero View Post
How did you get that result?
Feb21-12, 06:19 PM   #5
t = 9 sec
so i did the following:
600 = uy + 1/2*9.8*9^2
solving for uy I got 22.6
Feb21-12, 06:27 PM   #6
t = 9 sec
you want to use the displacement in the y-axis, not the x-axis
Feb21-12, 06:34 PM   #7
Mentor
t = 9 sec
For one thing, you are dealing with the vertical motion, not the horizontal. For another, you'll need a different kinematic equation--one relating velocity and time. (Using the equation you chose will trivially give you a zero initial velocity--which you already should know.)
Feb21-12, 06:37 PM   #8
ah yes. okay so that means 400 = uy*9 + 1/2 *9.8*9^2
so uy = .34
and i guess i did ux wrong, so ux is actually 600 = ux*9, giving ux = 67
but from here i still don't know how to find the final velocity
Feb21-12, 06:44 PM   #9
Mentor
so uy = .34
No. Done more accurately, you'll get uy = 0. (9 seconds is just an approximate answer.) Realize that that equation gives the initial velocity, which is not what you want. You should know that the initial vertical velocity is zero. (You used that fact to find the time.)
No, you were right the first time. (How did you find the time?)
How does velocity change for accelerated motion? What's the definition of acceleration?
Feb21-12, 06:49 PM   #10
velocity increases due to acceleration... a = change in velocity/change in time
so we have a change from zero to 66.4 over the course of 9 seconds
meaning acceleration is 7.4 m/s ?
and i know v = vi + at
so i feel like i could do v= 0 + 7.4*9
giving me 66.4, which is wrong.
Feb21-12, 06:52 PM   #11
Mentor
Good. Now apply that to the vertical motion.
No, the horizontal motion is not accelerated.
That's the equation you need. Apply it to the vertical motion.
Feb21-12, 06:54 PM   #12
Mentor
What is the acceleration of a falling body?
New Reply
Thread Tools
Similar Threads for: Horizontal projectile, NOT GIVEN INITIAL VELOCITY
Thread Forum Replies
Initial Velocity of a Projectile Introductory Physics Homework 2
For projectile motion, can the y-final velocity be less than the y-initial velocity? Introductory Physics Homework 1
Horizontal motion problem involving coefficient of friction and initial velocity. Introductory Physics Homework 2
Why does drop time remain constant regardless of initial horizontal velocity? General Physics 5
Initial Velocity of a Projectile Advanced Physics Homework 2
