Intercepts in quadric surfaces?
  • Thread starter Thread starter yoohyojinn
    Surfaces
yoohyojinn
Intercepts in quadric surfaces??
How many intercepts can an ellipsoid have?
First of all, I don't understand what exactly "an intercept" means in quadric surfaces.
in two dimensions, intercepts are the points that the graph meets with x&y axes.
So in three dimensions, do intercepts still mean the points that the surface meets with x,y,z axes?
if what I understand is right, an ellipsoid can have at least 0 intercept, and at most 6 intercepts.
And an elliptic parabaloid can have at least 1 intercept, and at most 6 intercepts.
is it right??
Thanks.
Seems reasonble to me.
I think that 6 is too many - I don't see how it could have more than 5 intercepts.
yoohyojinn said:
is it right??
Thanks.
oh yes, yes, yes, you are right.
I was confused with visualizing it.
an elliptic paraboloid can have at most 5 intercepts.
thanks.
What if it was an elliptic paraboloid which was rotated so that its axis of revolution was not parallel to an axis? Couldn't it then achieve 6 intercepts?
that sounds right
I thought about that possibility (briefly), but it didn't seem to make a difference. If you spend more time at it than I did, you might be able to come up with a scenario in which there are 6 intercepts for the paraboloid.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
