New Reply
Help with Isolation amplifiers
Share Thread Thread Tools
Mar30-12, 06:59 AM   #1
Hello. I need help in finding the following isolation amplifiers:
1. I'm measuring current of approximately 600 A using LEM current transducer LF 1005-S (which gives an output of 200 mA for 1000 A). LEM transducer need DC power supply, and i use bipolar 15 V dc power supply. I need isolation amplifier (200 mA - 500 mA to 10 V) that i'll connect to the DC supply and LEM transducer. Then i'll take voltage from amplifier and connect it to the acquisition card Personal DAQ 3000 USB (card has only voltage input).
2. I have 6 Pt 100 probes connected in series with current source (1 mA). I need isolation amplifiers for Pt 100 probes (measuring temperature) which converts cca 200 mV - 500 mV to 10 V.
Thanks
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
Mar30-12, 11:48 AM   #2
Mentor
Quote by SEYOboy View Post
Thanks
Welcome to the PF.
On your first question, isn't the LEM current sensor already isolated? The datasheet says that it is galvanically isolated from the wire whose DC/AC current it is sensing...
http://www.google.com/url?q=http://w...CO5jqPw84QG8RQ
Mar30-12, 03:19 PM   #3
Quote by berkeman View Post
Welcome to the PF.
LEM sensor has current output, and I need voltage output for personal daq 3000 card. If you connect LEM sensor with resistor there'll be too huge losses (around 1.8 W for 200 mA and 46 Ω resistor).
Mar30-12, 04:13 PM   #4
Mentor
Ah, I think it is just a language issue with the term "isolation amplifier". I think you are asking about how to do the current-to-voltage conversion efficiently, which has nothing to do with isolation amplifiers.
The term Isolation Amplifier usually refers to an amplifier that gives some amount of galvanic isolation between input and output:
http://en.wikipedia.org/wiki/Isolation_amplifier
You would use such an amplifer if you had a sensing circuit connected to the AC Mains, and you wanted to get that sensed information into a low-voltage circuit (like a microcontroller). The isolation may be done with optoisolators or other means.
But in your first application with the current sensor, the LEM module already gives you the galvanic isolation. I think you are asking how to convert the 200mA max output current of the sensor (which does appear to have a current mode output) into a voltage for reading by your ADC. Since it is a current mode output, you should be able to use the minimum size resistor specified in the datasheet (5 Ohms), and then just use an opamp with the appropriate gain to give you the maximum output voltage for your ADC range (which I think you list as 10V).
Mar30-12, 04:15 PM   #5
Mentor
BTW, will the current you are sensing be AC, DC or a mix? If AC, then you will have to add an offset to the output of your current-to-voltage converter opamp circuit, if you want the output to be in the 0V to 10V range.
Mar30-12, 06:57 PM   #6
LEM current transducer is this one http://docs-europe.electrocomponents...6b8028ffae.pdf
Current is AC. Input in daq card is +-10V.
Mar30-12, 07:03 PM   #7
Mentor
So you can use a load resistor R(M) of just a few Ohms to save on power.
Let's say you use a 1 Ohm precision (0.1%) resistor. What power rating does it need to have in your application? And what does the opamp circuit look like to turn the voltage across R(M) into your +/-10V output signal?
New Reply
Thread Tools
Similar Threads for: Help with Isolation amplifiers
Thread Forum Replies
What is meant by isolation? Biology 3
DC to DC Isolation? Electrical Engineering 7
Amplifiers Introductory Physics Homework 0
amplifier with feedback Electrical Engineering 3
