| New Reply |
The minimum cost of converting static pressure into dynamic pressure |
Share Thread | Thread Tools |
| Apr15-12, 08:28 PM | #1 |
Can static pressure be induced to becoming dynamic pressure through the use of "right-angle forces" with respect to particle velocities? I imagine that one could accomplish this with an ionized gas and a magnetic field. This would reduce the amount of work that is need to accelerate the gas. Furthermore, what happens if one were to convert so much of the static pressure into dynamic pressure that the static pressure would fall below the ambient pressure of the atmosphere? Could the atmosphere itself do radial work on our system as soon as we relieve the dynamic pressure by allowing that dynamic pressure to do rotational work?
| Apr15-12, 08:43 PM | #2 |
Mentor
I'm not really sure what you mean, but all you need to convert static pressure to velocity pressure is a nozzle. And nozzles can be pretty efficient.
Also, you can use a high velocity airstream to induce additional flow. This is called induction. |
| Apr15-12, 08:55 PM | #3 |
| Apr15-12, 09:19 PM | #4 |
Mentor
I can't make sense of that either. Fixed volume of what?
| Apr15-12, 09:27 PM | #5 |
| Apr15-12, 09:35 PM | #6 |
Mentor
Velocity pressure is from air being in motion. How do you propose to have air in motion if there is nowhere for it to go? It is very unclear to me what you are asking. Could you please explain in more detail what you are hoping to accomplish?
| Apr15-12, 09:48 PM | #7 |
| Apr15-12, 10:09 PM | #8 |
Mentor
How is that not an explicit violation of conservation of energy?
| Apr15-12, 10:30 PM | #9 |
| Apr16-12, 02:37 AM | #10 |
Recognitions:
http://en.wikipedia.org/wiki/Ion_thruster |
| Apr16-12, 07:52 AM | #11 |
| Apr16-12, 12:24 PM | #12 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: The minimum cost of converting static pressure into dynamic pressure
| Thread | Forum | Replies | ||
| static pressure vs. dynamic pressure | Mechanical Engineering | 19 | ||
| How does dynamic pressure affect static pressure? | General Physics | 3 | ||
| Static and Dynamic Properties of Blood Pressure | Biology | 2 | ||
| Question about dynamic pressure vs pressure on plate | General Physics | 7 | ||
| Dynamic & Static propeller pressure | Mechanical Engineering | 4 | ||
