| New Reply |
How does siphon work? |
Share Thread | Thread Tools |
| May8-12, 04:54 PM | #18 |
Mentor
How does siphon work?Awful. Just awful. |
| May8-12, 04:56 PM | #19 |
Mentor
| May8-12, 05:24 PM | #20 |
And, if most liquids have very low tensile strength, then the tensile strength explanation is not actually relevant to most liquids. It is an interesting slant on the whole thing and adds a healthy amount of confusion to the situation. Could turn out to be a bit of a big-endian and little-endian clash here. |
| May8-12, 09:10 PM | #21 |
After all, I can reach into a sink full of water and pull the water apart very easily. But then again, if I fill a hypodermic syringe with water, put my finger over the little end thing, and pull on that big-endian thing, I feel a tension. So something is going on. ![]() Anyways, my faux homework problem was based on the PDF I briefly looked at yesterday: www.phys.uhh.hawaii.edu/documents/TPT-final.pdf |
| May9-12, 04:01 AM | #22 |
If you did the same syringe thing up in space, you could easily pull the plunger out and the water would start to bubble as the pressure inside became less than the vapour pressure. |
| May9-12, 05:46 AM | #23 |
| May9-12, 06:16 AM | #24 |
For equal pressure siphons (be it 1bar or vacuum on both ends) gravity (acting on the fluid) is the driving mechanism. Equal pressure on both sides cannot drive anything. It just creates an offset (equal on both sides) to gravity. But it is the differential weight of the columns which causes the flow, and thus "drives" it. |
| May9-12, 06:20 AM | #25 |
It all boils down to gravity in the end, of course. No g, no AP.
| May9-12, 06:55 AM | #26 |
| May9-12, 08:27 AM | #27 |
Even though the weight of the fluid in the upper siphon section is greater than that in the lower container, the fluid still flows downwards. I liked this line from the wiki article: But under atmospheric pressure, a broken siphon(one with an air bubble) works also. But I think you can still use the chain analogy here also, as long as there are pistons at each end of lots of little chains. Hence my new "Infinite layers of jello shots siphon" model. ![]() Which I will explain in about 23 hours, as I'm late for work again. |
| May9-12, 08:44 AM | #28 |
Mentor
It could be said more simply that the driving force is the difference in hydrostatic pressure, but that may be what causes people to think about tension. It works mathematically but not conceptually. |
| May9-12, 08:47 AM | #29 |
| May9-12, 09:11 AM | #30 |
So, we've eliminated the tension effect for all but 'special' liquids. We are now just chasing our tails about what causes what. If it were not for gravity then there would be no siphon. Atmospheric pressure (only there because of gravity) is necessary to produce the condition at the top of the U where there is fluid available to flow down the other side (this downward flow also needs gravity).
A normal siphon will not work without enough atmospheric pressure. What does it matter if we say that the pressure "drives" the siphon or not? On the downward leg, the hydrostatic pressure is Higher than that on the lower surface - so liquid can flow down. As with all hydrostatic situations, we know that the cross sectional area of tubes does not affect pressure so that is a red (or in the case of the picture, blue) herring. If someone looks at it one way or another (yet using the right mechanisms but in a different order [Eric Morcambe rules]) do they need to be afraid of being 'WRONG"? Is it the term "driving" that is throwing everyone into this frenzy. That word is not a front-line, defined term in Physics so stop worrying. There is no need to bicker further if we have all learned something from this thread. I hope that all this thread has not just managed to confuse people. |
| May9-12, 12:24 PM | #31 |
| May9-12, 01:23 PM | #32 |
Whatever be the pressure of the atmosphere, or even if there is no atmosphere, the difference of hydrostatic pressure at the points B and C at the top for a given siphoning setup will be the same.
| May9-12, 04:26 PM | #33 |
There is no mention of the actual tensile strength of that "ionic liquid". How many metres would the tension support or was the inverted U that we saw as much as the tension would support?
The video was an interesting diversion but it says very little about real siphons with real liquids. It has been shown that a siphon works even with a bubble in it so that evidence shows nothing other than how a very novel liquid behaves. Plumbers use water and barometers use mercury; real, everyday liquids and it is those that are of real interest. |
| New Reply |
| Thread Tools | |
Similar Threads for: How does siphon work?
| Thread | Forum | Replies | ||
| Hydrostatics and work done by a gas in a situation similar to a siphon | Introductory Physics Homework | 2 | ||
| Work done by a siphon. | Introductory Physics Homework | 17 | ||
| efficiency of siphon | Classical Physics | 7 | ||
| what is siphon break and reverse siphon? | Mechanical Engineering | 0 | ||
| Siphon | Introductory Physics Homework | 0 | ||
