Calculate G-Force: How to Measure Gravity's Force
  • Thread starter Thread starter SignSeeker7
    G-force
To calculate G-Force, use the formula V^2/R, where V is the velocity in meters per second and R is the radius in meters. G-Force is essentially a measure of centripetal acceleration and represents the ratio of a specific force to gravitational force on the same object. For example, if a rider on a merry-go-round with a radius of 15 meters travels at 8 m/s, the calculated G-Force is approximately 0.2724, or 27.24% of Earth's gravitational pull. This concept also applies to linear acceleration, such as in a rocket. Understanding G-Force helps quantify the effects of acceleration in various scenarios.
SignSeeker7
How do you calculate G-Force? I know that one g is the force gravity exerts on a particular mass (I think). But how exactly do you figure it out, particularly with objects spinning in a circle, like a merry-go-round?
V^2/R
Velocity in m/s with that number squared divided by the radius in meters.
Ferraridude said:
V^2/R
So, G-Force is the same as centripetal acceleration?
"G force" is just the ratio of a given force to the force due to gravity on the same object. Think of it as a unit of measure, it's not a special kind of force. Typically, "G forces" are referring to pseudo forces experienced in an accelerating reference frame.
Now, if you wanted to know the gravitational attraction between two objects, then you'd use Newton's law of gravitation.
Yes, if you are going in a circle, or even changing direction. You can also get g force from linear acceleration. If you were in a rocket that could accelerate at 4 g's straight up, or 39.2 m/sec^2 you would be subject to 5 g's. Four from the rocket and one from the Earth.
If you were going around a merry go round with a radius of 15 meters at a velocity of 8 m/s, this is how you would calculate the G-forces.
8^2=64
64/15=approximately 2.67.
So now, you have your m/s^2 for the acceleration.
2.67/9.8 m/s^2 (9.8 m/s^2 is the acceleration of the Earth's gravity)=.2724
So, we can now see that the centripetal force on a merry go round rider with that velocity around a circle with that radius, we are feeling .2724 G's of acceleration, or 27.24% of Earth's gravitational pull.
Likes Patrick ryans
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
