How do electron shells and subshells/orbitals relate?
  • Thread starter Thread starter ctownsley
    Electron
The discussion clarifies the structure of electron shells and subshells in atoms, emphasizing that the first shell (n=1) contains only an s subshell, holding 2 electrons. The second shell (n=2) includes both an s subshell and three p orbitals, allowing for a total of 8 electrons (2 from 2s and 6 from 2p). As the principal quantum number increases, additional subshells are introduced, with n=3 containing s, p, and d subshells, accommodating up to 18 electrons. The explanation highlights that the number of orbitals increases with each subshell type, affecting the total electron capacity of each shell. Understanding this hierarchy of shells and subshells is crucial for grasping atomic structure in chemistry.
ctownsley
In physical science I was told that all elements could have 2 electrons in the first shell, and 8 in all the rest. I'm trying to study chemistry over the summer with khan academy but I am really having a hard time grasping the idea of subshells, or orbitals. The second shell can have up to 8 electrons (I have by now found that this number in fact increases with the number of shells), but with only x y and z orbitals the total electrons are only 6. I have no idea if any of this is correct but I'm deeply confused. I just need a clear explanation of how shells and subshells relate
Chemistry news on Phys.org
Hi, hopefully I can help!
When n=1 ( Principal quantum shell 1 ),
there is 1 s-subshell which can hold 2 electrons.
When n=2, it contains the 2s and 2p subshells! Like you've stated, the p-subshells have 3 orbitals, namely 2px, 2py and 2pz. Each orbital can hold 2 electrons. Thus the p-subshell can hold a maximum of 8 electrons, 6 from the 3 p-orbitals and 2 from the s-orbital.
When an atom has an electronic configuration of up to n=2 ie. it has 2 electron shells, it mainly means that it can hold a maximum of 10 electrons( 2 from n=1 and 6 from n=2). Any more will go to the next energy level/principal quantum shell 3.
At n=3, it contains the s,p and d subshells. d-subshells have 5 orbitals, and thus d-subshells alone can hold 10 electrons max. Now, don't forget the s and p subshells, so at n=3, a total of 18 electrons can be held.
Any atom that has a d-sub-level ie. up to n=3 can hold a maximum of 30 electrons.
If you add it all up, where n=3 has 18 electrons, n=2 has 8 and n=1 has 2, you'll get 28. But if you've reached the part about the 4s subshell being lower in energy than the 3d subshell, that gives you an additional 2 electrons, which was how I got the 30 max.
Basically, the biggest is the electron shell and then the sub shells and orbitals, the smallest.
As your electron shell number increases ie. n=1, n=2 etc, the number of subshells you have within your electron shell increases too, eg n=1 has only the s subshell, n=2 has the s and p sub shells. The orbitals are within the subshells, and their numbers are standard, s subshell has 1 orbital, p subshell has 3 orbitals, d subshell has 5 orbitals and f subshell has 7 orbitals.
Hope this helped. It was confusing for me at first too.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
