Excel spread sheet : related to formula copying
  • Thread starter Thread starter manjuvenamma
    Excel Formula
The discussion revolves around how to automate the population of a new table in Excel based on a given set of numbers in an existing table. Participants explore methods for copying formulas to achieve specific calculations involving products of cell values and their corresponding row and column headers.
  • Homework-related
  • One participant describes a need to create a new table where the first row and column are duplicates of an existing table, while other cells require specific calculations based on their position.
  • Another participant suggests that the task could be accomplished easily with VBA, though they express uncertainty about achieving it with a cell formula.
  • A different participant explains a method for copying formulas using the fill handle in Excel, emphasizing the importance of relative and absolute addressing in formula copying.
  • A participant clarifies their requirement that the new table's cells should be populated based on a specific product calculation that does not follow traditional relative addressing.
  • One participant expresses gratitude for the clarification on using absolute references in Excel formulas, indicating a better understanding of the concept.
There is no consensus on the best method to achieve the desired outcome, as participants propose different approaches (VBA vs. cell formulas) and clarify their specific needs regarding formula copying.
Participants discuss the nuances of relative and absolute referencing in Excel formulas, highlighting the importance of understanding these concepts for effective formula application.
manjuvenamma
I have a table of numbers say 12 X 12 i.e A1 cell to L12 cell. All of them have numbers filled in.
I have to create another table of identical size. first row and first column numbers are just duplicated in the new table i.e.A1 to A12 (first column) A1 to L1 (first row) cells are just copied into the new table without any changes.
All other cells of the new table are to be populated as follows:
for example: cell corresponding to b9 is to replaced by the product of three numbers (i) b9,
(ii) a9 (first element of the same row) and b1 (first element of the same column).
Another example: j6 is to replaced by the product of j6, a6 (first element of the same row) and j1 (first element of the same column).
I can do this manually by writing formula in each cell. I want to do automatically by writing a formula in one cell and copying the same in all other cells of interest.
Can this be down and how?
Computer science news on Phys.org
it can be done very easily w/ VBA but I wouldn't know how to do it with a cell formula although I wouldn't be surprised if it COULD be done w/ a cell formula
EDIT: I've done the VBA --- if you want it, send me an email (NOT a PM)
There is a simple copy paste for that.
Write the formula in the first cell. Note that there is a little black dot in the lower right corner of the cell where the cursor is. Aim the mouse on that and the pointer changes to a small cross. Now drag the mouse over all the cells where you want the formula copied.
Note that the relative geometry of the copies stay in tact. so if you drag the formula =a6*a7 one to the right and one down, the copy will read =b7*b8 etc
If you want absolute geometry, you put a $ before the row or column that should remain pointing to the same column ($b6) or row (b$6) or both ($b$6) if the copy needs to look at the single cell only.
Andre, thanks for the reply. Here neither I need neither the absolute addressing nor the relative addressing. Basically in the new table (except the first row and the first column) every other cell is to be replaced by the product of corresponding cell in the original table,
the first cell of the corresponding row and the first cell of the corresponding column in which this cell sits. So it changes with each cell but NOT in the relative fashion.
Thank you, very much, Andre. I got it now and it is working. I was thinking that we can use $ in singly like $A37. Now I realized we could used like A$37 too.
  • · Replies 32 ·
14K
  • · Replies 18 ·
  • · Replies 17 ·
