Question about artificial gravity (orbitting earth) in space
In summary, the concept of artificial gravity is based on the idea that a large enough tube orbiting an axis at a fast enough speed can create a gravitational pull similar to that of Earth's. However, the Earth's rotation at 1,600 km/h does not have a significant effect on perceived gravity at the Earth's surface. This is because most of the perceived gravity is due to the Earth's actual mass. Astronauts appear weightless because they are being pulled down by gravity at the same rate as their spaceship. And in the example of a spinning tube, the outer end will experience a perceived gravity due to the centrifugal force.
ihaveabutt
Considering artificial gravity can be created in a large enough tube orbiting an axis at a fast enough speed, consider the following:
If a spaceship is in a fixed orbit around the earth, wouldn't it be bound to Earth's axis by its gravitational pull? And if so, since the Earth rotates at 1,600 km/h, wouldn't there be a point where the angular momentum would be enough to mimmick the effects of gravity onboard? (<--more important question | not as important question -->) And if that's the case than why do astronauts always appear weightless?
Yep.
The rotation of the Earth has only a small effect on the perceived gravity at the Earth's surface. In other words, the Earth is just spinning too slowly to have much effect (except maybe on the tides). So almost all of the perceived gravity at the Earth's surface is due to actual gravity caused by the mass of the Earth.
They have nothing else to compare their motion to. Here on earth, the surface of the Earth is stationary, while we are getting pulled down by gravity. But astronauts get pulled down by gravity at the same rate as their spaceship, so they do not experience gravity on the floor of their spaceship.
Also, the example of the spinning tube, any person inside will naturally be falling away from the axis of rotation, while the tube stays rigid, so they do experience a 'perceived' gravity on the outer end of the tube.
1. How does artificial gravity work in orbit around Earth?
Artificial gravity in orbit around Earth is created by centripetal force, which is the force that pulls objects towards the center of a circular motion. By rotating the spacecraft or space station, this force can simulate the feeling of gravity for those inside.
2. Can artificial gravity be created on any spacecraft or space station?
Yes, artificial gravity can be created on any spacecraft or space station as long as it has the capability to rotate. However, the effectiveness of artificial gravity may vary depending on the size and speed of rotation of the spacecraft or space station.
3. Does artificial gravity have any negative effects on the human body?
There are some potential negative effects of artificial gravity on the human body, such as dizziness or motion sickness, which can occur during the transition from microgravity to artificial gravity. However, these effects can be minimized with proper training and acclimation.
4. Can artificial gravity be used for long-term space missions?
Yes, artificial gravity can be used for long-term space missions as it helps to mitigate the negative effects of microgravity on the human body, such as muscle and bone loss. It also provides a more comfortable and familiar environment for astronauts during extended periods in space.
5. Are there any alternative methods for creating artificial gravity in space?
Aside from rotational artificial gravity, there have been some proposed alternative methods such as using a spinning tether or a spacecraft's own propulsion system to generate centrifugal force. However, these methods have not yet been fully tested and may not be as effective as rotational artificial gravity.
  • Classical Physics
  • Classical Physics
  • Astronomy and Astrophysics
