New Reply
Complaint Why can't I edit my posts after 24 hours?
Share Thread Thread Tools
Dec29-12, 04:11 PM   #1
It seems that after a day, I can't edit my older posts. I've recently misled people in an older post of mine and I can't edit to correct it.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec29-12, 04:14 PM   #2
Recognitions:
Gold Membership Gold Member
That's just the way it is here (on purpose). Actually, I thought it was 8 hours, not 24.
Dec29-12, 04:17 PM   #3
Quote by phinds View Post
Well, now people are being misled... What's the point of this if it was done intentionally?
Dec29-12, 04:21 PM   #4
Recognitions:
Retired Staff Staff Emeritus
You can always post a correction in the thread.
Or you can report the post and say what needs to be corrected, then a mentor will correct it.
Dec29-12, 04:22 PM   #5
Alright, but what is the point of this feature? And if there is a point to it that I'm missing, why not just use moderated edits?
Dec29-12, 04:32 PM   #6
Evo
Mentor
The point is that there have been many instances of people intentionally changing or deleting posts which makes a thread useless after many people already responded. This is why people should quote all or part of the post they are responding to, so if the OP goes back and changes their post, the responder won't appear to be the one making the mistake. There are many reasons that there is a time limit. We've had instances of members getting angry and going back and deleting all of their posts in numerous threads, making the threads meaningless.
If you realize a mistake after 24 hours, it's easy to just post a correction in the thread.
Dec29-12, 04:40 PM   #7
Mentor
Quote by tahayassen View Post
It could be that the forum software doesn't have this feature. Maybe one of the Admins can comment on this.
Dec29-12, 04:48 PM   #8
Quote by Evo View Post
Doesn't vBulletin have post history? Aren't there rollbacks? Surely there is a more elegant method?
Quote by jtbell View Post
If the admins can't setup moderated edits and it does turn out to be a limitation of the software, then maybe after 8 hours, the edit button can redirect to the report button.
Dec29-12, 04:56 PM   #9
Evo
Mentor
We don't have enough mentors to deal with minor edits. There would have to be a significant reason to have a mentor edit the original post when a new post containing the correction can easily be made within the same thread. We will do it as an exception.
In other words, it's always a good idea to proof read your post within the edit window.
Dec29-12, 05:00 PM   #10
Mentor
I see. Your position is that the mods aren't working hard enough.
Let me turn it around - what's to keep you from making a new post saying "I made a mistake yesterday, and..."
Dec29-12, 05:00 PM   #11
The unfortunate problem I have with creating a new post to correct an older post is when you make a mistake on the 3rd page, learn a couple of days later that you're wrong, and your correction is now on the 6th page.
Dec29-12, 05:04 PM   #12
@Vanadium 50: Don't take it personally. If my attitude seems a little off, it was probably caused by the frustration I felt before understanding the reason behind this intentional decision.
Dec29-12, 05:14 PM   #13
mfb
Mentor
The board software has an edit history (well, you can activate it), but it is a lot of work to check many posts - or even revert 100+ edits.
A feature which allows edits below the original post only (after 8 hours passed) would be nice, but I did not see that anywhere, so it would probably require significant coding effort.
That would be a reason to report your post, I think. No one likes wrong posts.
Dec29-12, 05:16 PM   #14
Mentor
I suggest creating a new post with your correction and then requesting (via the report button) that a short note pointing to the corrected post be added to the original.
Editing a post three pages back isn't a great idea, especially if it's been responded to. They won't see the correction.
Dec29-12, 05:31 PM   #15
Evo
Mentor
Quote by Doc Al View Post
I have to agree. This is not one of those "exceptions" where a correction to the original post would be important or helpful. Much better to post the correction as a new post.
Dec30-12, 04:05 AM   #16
Mentor
Isn't it 11 hours and 40 minutes (=700 minutes)? If not, it's been changed in the last few months.
Feb6-13, 10:38 AM   #17
Recognitions:
Homework Helper Homework Help
I made a mathematical mistake last night in a post and was unable to edit it around 10 am this morning, so I presume the time is less than 24 hours, which I personally find inadequate. I usually realize my mistakes after sleeping on them. Is allowing 24 hours a technical, or administrative hardship?
My concern is that although I worked quite hard to give a concise, clear, and correct account of an important topic, I failed by including a few speculative remarks, not marked as such. Now I cannot correct them and the result is that there is now no one place where just the correct remarks occur alone. I made a corrective comment in a later post, but that presents the reader with a more difficult challenge in trying to find a simple correct statement. If I try to excerpt the correct part and repost it, I feel guilty of "double posting".
I.e. the problem with later corrective posts is they are not marked in the earlier erroneous post, so you have to somehow accidentally read the correcting post in order to know about the earlier error. Is there some way to mark an erroneous post with a link to the later correcting one? That would not cause the problem mentioned above about causing other comments on the incorrect post to appear inappropriate. That would require some kind of augmenting edit of course, but not a deletion. But to me, just allowing at least 24 hours to edit would also go a long way to solving the problem.
New Reply
Thread Tools
Similar Threads for: Why can't I edit my posts after 24 hours?
Thread Forum Replies
Edit posts? Forum Feedback & Announcements 16
unable to edit own posts? Forum Feedback & Announcements 4
Can't edit posts! Forum Feedback & Announcements 34
Edit Posts Forum Feedback & Announcements 4
How do I edit old posts? Forum Feedback & Announcements 2
