New Reply
Rudin's Theorem 2.27
Share Thread Thread Tools
Jan2-13, 09:42 PM   #1
Prove the closure of E in a Metric Space X is closed. (page 35)
Rudin states:
if p∈X and p∉E then p is neither a point of E nor a limit point of E..
Hence, p has a neighborhood which does not intersect E. (Great)
The compliment of the closure of E is therefore open. WHY? I don't see it...
BTW, I know there are different ways to proving this, but I want to understand the last line jump. Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan2-13, 09:46 PM   #2
The compliment of E is therefore open. WHY? I don't see it...
What is the definition of open? What has Rudin just shown about an arbitrary point in X?
Jan2-13, 09:47 PM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
What is your definition of "open"?
Jan2-13, 09:49 PM   #4
Quote by Number Nine View Post
What is the definition of open? What has Rudin just shown about an arbitrary point in E?
E is Open if every p in E is an interior point (meaning there exists a neighborhood of p that is in E)
The problem we should say that the complement of E is open, not the complement of the closure of E.
Jan2-13, 10:08 PM   #5
I guess since the intersection of N(p) and E is empty then no point q of N(p) can be a limit point of E as this would mean every neighborhood of q will contain an infinite number of points in E. Hence the intersection of N(p) and "closure of E" is empty.
Is this correct?
Jan2-13, 11:31 PM   #6
Recognitions:
If any point not in E has an open neighborhood that does not intersect E then by definition the complement of E is open.
Jan2-13, 11:48 PM   #7
my bad, I forgot to add the word: "closure" in the last line of the proof. I just re-read it.
This is what is confusing me:
FROM: Hence, p has a neighborhood which does not intersect E.
We get: The compliment of the closure of E is therefore open.
Jan3-13, 06:34 AM   #8
Recognitions:
We have just shown that p is in the complement of the closure of E (call it A). We also showed that p has a neighborhood that is entirely in A. Hence, p is an interior point of that set A. Hence A is open.
Jan3-13, 09:59 AM   #9
Quote by Bachelier View Post
This doesn't make sense. It must be ##p\notin \overline E##, where ##\overline E## is the closure of ##E##, instead of ##p\notin E##.
Then, everthing is clear.
Jan3-13, 03:28 PM   #10
Quote by Erland View Post
This doesn't make sence. It must be ##p\notin \overline E##, where ##\overline E## is the closure of ##E##, instead of ##p\notin E##.
Since ##p\notin \overline E## then it is not a limit point, hence not every neighborhood of ##p## contains a point of ##E##.
Let ##N(p)## be the neighborhood with no common points with ##E##.
What about ##\overline E##? Is the ##\overline E \cap N(p)## an empty set because if it wasn't, then ##N(p)## will contain a limit point of ##E## and these will have neighborhoods that contain a point of ##E##?
"I understand everything about the proof, except for the part where we go from ##E## to ## \overline E## when we mention the complement. I want to make sure my reasoning is correct" Thanks.
Jan3-13, 04:11 PM   #11
You are right, I, and Rudin it seems, were a little bit too quick here. But it is as you write. If ##N(p)## intersects ##\overline E## in a point ##q##, say, then ##N(p)## is also a neighborhood of ##q##, and it must contain an element of ##E##, which was not the case. Thus ##N(p)## is a neighborhood of ##p## which does not intersect ##\overline E##.
Jan3-13, 05:06 PM   #12
You are right, I, and Rudin it seems, were a little bit to quick here. But it is as you write. If ##N(p)## intersects ##\overline E## in a point ##q##, say, then ##N(p)## is also a neighborhood of ##q##, and it must contain an element of ##E##, which was not the case. Thus ##N(p)## is a neighborhood of ##p## which does not intersect ##\overline E##.
Thank you. :)
New Reply
Thread Tools
Similar Threads for: Rudin's Theorem 2.27
Thread Forum Replies
Rudin Theorem 1.20 (b) Topology and Analysis 2
Rudin Theorem 2.41 Topology and Analysis 5
Rudin theorem 3.44 Topology and Analysis 2
Rudin Theorem 3.23 Topology and Analysis 1
Rudin 1.20 Theorem Calculus 9
