| New Reply |
Falling (toppling) rigid tower (uniform rod) |
Share Thread | Thread Tools |
| Jan14-13, 07:42 AM | #1 |
I am working on an animation, which involves a rigid, vertical tower falling (toppling) to the ground, and I am stuck at its core physics.
Actually this is the same as the thin uniform rod initially positioned in the vertical direction, with its lower end attached to a frictionless axis. I would need the angle (compared to the ground) of the rod in a given time. The tower is 50meters long. (It is a simple animation, the effect of gravity only is enough: no friction, no radial acceleration, no stress forces etc. is needed) Thanks in advance |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jan14-13, 10:10 AM | #2 |
So what have you tried to do to solve your problem?
Here is something to grit your teeth on with regards to moment of inertia. http://www.uta.edu/physics/courses/w...1116-20(F).pdf |
| Jan14-13, 10:35 AM | #3 |
Your tower is a pendulum, whose initial angle from "pointing down" is 180 degree. Starting from the pendulum's differential equation,
[tex] x'' + a \sin x = 0 \\ x''x' + a (\sin x)x' = 0 \\ \frac {x'^2 - {x'}_0^2} {2} - a(\cos x - \cos x_0) = 0 [/tex] ## x_0 = \pi ## (the pendulum is upward from "pointing down"), so [tex] \\ x' = \sqrt {{x'}_0^2 + 2a(\cos x + 1)} \\ \int_{\pi}^x ({x'}_0^2 + 2a(\cos x + 1))^{-1/2} dx = t [/tex] The latter integral, as far as I can tell, does not exist in the closed form, but it can be tabulated between ## \pi ## (upward) and ## \pi/2 ## (toppled), which will give you the trajectory you want. You will need ## {x'}_0 ## which is the initial angular velocity, and you will need ## a ##, which is ## \frac {3g} {2L} ## for a uniform rod, ## L ## being the length. |
| New Reply |
| Thread Tools | |
Similar Threads for: Falling (toppling) rigid tower (uniform rod)
| Thread | Forum | Replies | ||
| uniform chain falling down | Introductory Physics Homework | 12 | ||
| Wire Loop falling through uniform magnetic field | Advanced Physics Homework | 1 | ||
| Rain Drops falling down in a uniform cloud | Introductory Physics Homework | 2 | ||
| acceleration of a falling tower | Introductory Physics Homework | 2 | ||
| Motion of a Uniform Chain falling....I desperatly need help | Advanced Physics Homework | 5 | ||
