| New Reply |
simple harmonic oscillation |
Share Thread | Thread Tools |
| Jan19-13, 08:49 AM | #1 |
Trust me this is not homework... My last two questions were removed cause they looked like homework... I understand its the forum policy... From now on I will post the 'seemingly homework' on the homework sections...
Suppose,there's a rod of mass m1 hanging from a point... And a mass m2 is attached to the other end... If I let it oscillate will it present a simple harmonic oscillation... If it does,what will be the period... My intuition said no...(well the pendulum's string always has to be mass less) But when I thought mathematically, what's the difference if I find the center of mass of (m1+m2) & solve it... That would only change the L... And I can find the differential equation by τ=Iα... thinking the center of the mass of m1+m2 acts at a distance L... and I would find the moment of inertia of the system of m1+m2... so what do u think? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jan19-13, 10:46 AM | #2 |
Your idea to think about the moment of inertia of the pendulum is a good one. The rotational kinetic energy of a cylindrically symmetric object rotating around an axis through its end is ##K=\frac{1}{2}I\omega^2 = \frac{1}{2}I\dot{\phi}^2## where ##\phi## is the angle between the vertical and the pendulum's central axis (with the over dot meaning the time derivative) and I is the moment of inertia around the end. If the mass of the pendulum is ##m## and the distance from the pivot to the centre of mass is ##l##, then the gravitational potential energy of the pendulum is ##U=mgl(1-\cos\phi) \approx \frac{1}{2}mgl\phi^2## where the approximation is valid for small angles of oscillation. Thus, in the small angle approximation, we have the Lagrangian:
##L = K - U = \frac{1}{2}I\dot{\phi}^2 - \frac{1}{2}mgl\phi^2## The universal identifier for simple harmonic motion in some coordinate is a Lagrangian which is quadratic in that coordinate and its derivative, which we have above for the ##\phi## coordinate. This comes straight from the Euler-Lagrange equations, since ##L=\frac{1}{2}(A\dot{q}^2 - Bq^2)## (for arbitrary constants A and B, with a factor of a half taken out for computational convenience) implies: ##A\frac{d^2q}{dt^2} + Bq = 0## This is the differential equation for simple harmonic motion with frequency ##\omega = \sqrt{\frac{B}{A}}##. So, you can read off the harmonic frequency directly from the Lagrangian for the pendulum: ##\omega = \sqrt{\frac{mgl}{I}}##. This is related to the period of oscillation in the usual way. The general case for a less symmetric pendulum follows similarly using the principle moments of inertia about the centre of mass (which you can either use to determine the moments around the end using the parallel axis theorem, or else just separate the motion into rotation about the centre of mass and the motion of centre of mass itself). This is done in the classical mechanics text by Landau and Lifshiftz in the example problem 3 of section 32, if you want more details. |
| Jan20-13, 12:33 PM | #3 |
Thank you for your answer... Btw, what was the period u found for this problem?
Why our simple pendulum's string always is said to be massless... It provides harmonic oscillation even if it has mass... |
| Jan20-13, 12:40 PM | #4 |
| Jan20-13, 02:00 PM | #5 |
U used m... Are u referring to the center of mass of m1+m2 at L distance?
| Jan20-13, 04:48 PM | #6 |
| Jan20-13, 07:13 PM | #7 |
I found
ω^2=2g(m1+m2)/l(m1+2m2) Can u please check my calculation? |
| Jan21-13, 09:36 AM | #8 |
| Jan21-13, 09:42 AM | #9 |
Cylindrical symmetric is necessary for the specific formula I worked out, which is what the sentence you're quoting is referring to. You're right that there is still SHM in the non-symmetric case—the reference I gave works that out explicitly. The point is that in the general case, the motion of the body needs to be decomposed into rotation around each of the three principal axes of inertia and so rotational kinetic energy has three terms. So, the formula I gave needs to be replaced with something more general (given in L&L) to get the angular frequency of a non-symmetric pendulum.
| Jan21-13, 09:55 AM | #10 |
I was thinking in terms of a two dimensional object swinging around one axis - which is a 'trivial' case, I guess. Anything more would get a lot harder. If you had a three dimensional object hanging from a universal bearing then it could have different MIs about different axes and it could also be spinning about another axis. Could you not, still, break this down into three motions, though - two with a restoring force towards the vertical (giving two different periods) and one rotation at a constant rate around an axis between the pivot and the CM? Perhaps there's something more.
| Jan21-13, 10:07 AM | #11 |
| New Reply |
| Thread Tools | |
Similar Threads for: simple harmonic oscillation
| Thread | Forum | Replies | ||
| simple harmonic oscillation | Introductory Physics Homework | 1 | ||
| Simple Harmonic Oscillation | Advanced Physics Homework | 3 | ||
| Simple harmonic oscillation | Introductory Physics Homework | 1 | ||
| Simple harmonic oscillation question | Introductory Physics Homework | 2 | ||
