What is the difference between Var(X) and Cov(X,X)?
  • Context: Undergrad
  • Thread starter Thread starter Rasalhague
The discussion centers around the relationship between variance and covariance, specifically questioning whether Var(X) is equivalent to Cov(X,X). Participants explore definitions, calculations, and interpretations of these statistical concepts, with a focus on discrete random variables.
  • One participant asserts that Var(X) equals Cov(X,X) and provides calculations to support this claim, but questions their understanding of covariance.
  • Another participant challenges the initial calculations, stating that Cov(X,X) should be computed as E[(X-EX)(X-EX)], leading to a different result for covariance.
  • A third participant expands on the definition of covariance, emphasizing the need to apply the expectation operator correctly and suggesting that Cov(X,X) is equivalent to variance.
  • References to definitions from literature are made, with one participant citing Simon & Blume and another referencing Robert J. Serfling's work, indicating potential discrepancies in definitions of covariance.
  • Concerns are raised about differing definitions of covariance found in various sources, suggesting that there may be multiple interpretations of the concept.
Participants express disagreement regarding the calculations and definitions of variance and covariance, with no consensus reached on the correct interpretation or application of these concepts.
Participants note that definitions may vary based on the context of discrete versus continuous random variables, and there are unresolved questions about the implications of these differences on the calculations presented.
Rasalhague
Var(X) = Cov(X,X) ??
[tex]Var(X)=\sum_{i=1}^N P(X_i)(X_i-EX)^2.[/tex]
[tex]Cov(X,Y) = \sum_{i=1}^N\sum_{j=1}^M P(X_i,Y_j)(X_i - EX)(Y_j - EY).[/tex]
If, for instance, [itex]P(X_i) = 1/N[/itex] and [itex]X = Y = (1,2,3)[/itex], then
[tex]Var(X) = \frac{1}{3} ((1-2)^2 + (2-2)^2 + (3-2)^2) = \frac{2}{3},[/tex]
but
[tex]Cov(X,X) = \sum_{i=1}^3 \sum_{j=1}^3 \frac{1}{9} (X_i - EX)(X_j - EX)[/tex]
[tex]=\frac{1}{9}((1-2)^2+(3-2)^2+2(1-2)(3-2)) = 2 - 2 = 0??[/tex]
There are 9 values of (X,Y); each occurs with equal probability. I've omitted the terms that contain (2-2) from the summation. Apparently I've misunderstood something about the definition of covariance, but what?
This formula is wrong.
Here is how you calculate it. By definition, the covariance is
[tex]Cov(X,X)=E[ (X-EX)(X-EX) ][/tex]
So define the random variable [itex]Z=(X-EX)(X-EX)=(X-2)^2[/itex]. The covariance is EZ. Now, if X takes on the values 1,2 and 3. Then Z takes on the values 0,1. Furthermore [itex]P\{Z=0\}=P\{X=2\}=1/3[/itex] and [itex]P\{Z=1\}=P(\{X=1\}\cup \{X=3\}) = 2/3[/itex].
Thus
[tex]Cov(X,X)=EZ = \sum_{k=0}^1 k P\{Z=k\} = 2/3[/tex]
Hey Rasalhague.
I don't know what you did, but Ill use the expanded form of covariance in your definition.
Cov(X,X)
= E[(X - E[X])(X - E[X])]
= E[X^2] - E[X]^2.
You are not applying the expectation operator correctly since you are need to apply the definition of the expectation to the whole definition (i.e (X-E[X])(X-E[X) and this means taking into account shifts by the mean.
If you expand the Covariance operator you get:
Cov(X,Y) = E[XY] - E[X]E[Y] and this is done using some simple algebra which leaves us with
Cov(X,X) = E[X^2] - E[X]^2 which is the same as the variance.
You are not calculating the variance or covariance but something that I have absolutely no idea with.
The formula defines covariance for discrete variables in Simon & Blume (1994): Mathematics for Economists, end of section A5.4, and in Robert J. Serfling's online intro 'Covariance and Correlation', formula (1) which he identifies with E[(X-EX)(Y-EY)P(X,Y)] in the formula which follows that. Serfling also states that P(X,Y) means
[tex]P_X(X)\cdot P_Y(Y)[/tex]
which in my example makes P(X,X) = (1/3)(1/3) = 1/9. Perhaps you could explain how you would calculate an example where [itex]X \neq Y[/itex], e.g. X = (1, 2, 3) and Y = (1, 4, 9).
I'm not sure how to reconcile Serfling's formula (1) with the way Wolfram Mathworld writes it out explicitly for the case where N = M:
http://mathworld.wolfram.com/Covariance.html
Are there two somewhat different concepts each called covariance, each corresponding to its own way of defining the mean of the product of two random variables?
Ah, reading further on that Mathworld article, it seems one definition concerns real-valued random variables from a finite sample space, another definition concerns tuples of such random variables. But still, there appear to be a variety of concepts here to which the name covariance is attached, with disagreement over certain points, and Mathworld doesn't give an explicit version of the more general definition.
  • · Replies 17 ·
