New Reply
Why is crankcase oil supplied to sleeve bearings?
Share Thread
Jan19-13, 09:21 PM   #1
(Diagram attached)
Why is crankcase oil supplied to sleeve bearings in the connecting rod?Does the oil film act like in a journal bearing?
I was reading about compressors and there is a mechanism called a 'crosshead'(see diagram) that converts rotary to reciprocating motion. Its funny how oil is used instead of real bearings.
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Jan19-13, 09:58 PM   #2
Recognitions:
Homework Helper Homework Help
Bearings require lubrication or they will seize, thus destroying the engine.
Jan19-13, 10:17 PM   #3
but,there are no needle/round bearings in the crosshead.Its just oil flowing throw the crank pin that is taking-up all the rotation,which is what surprises me.
I would imagine the same lubricating mechanism in a IC engine for automobiles. Since there always exists the phenomenon of blow-by in IC engines,what is to ensure that the crank oil always reaches the pin in the first place?
Jan20-13, 03:11 AM   #4
OCR
Quote by marellasunny View Post
there is a mechanism called a 'crosshead' that converts rotary to reciprocating motion.
marellasunny,
A crosshead is a mechanism used in large reciprocating engines and reciprocating compressors to eliminate sideways pressure on the piston, caused by the connecting rod.
http://en.wikipedia.org/wiki/Crosshead
http://marinediesels.info/2_stroke_e.../crosshead.htm
The connecting rod connects the piston to the crankshaft... the connecting rod is actually what converts the rotating motion of the crankshaft into linear motion (reciprocating motion).
Or, vice versa... linear into rotating motion.
http://en.wikipedia.org/wiki/Connecting_rod
http://en.wikipedia.org/wiki/Connect...ustion_engines
http://en.wikipedia.org/wiki/Connect...#Compound_rods
The bearings are 'real'... they're called plain bearings, or journal bearings, as opposed to rolling-element bearings.
http://en.wikipedia.org/wiki/Journal_bearing#Two-piece
http://en.wikipedia.org/wiki/Rolling-element_bearing
http://en.wikipedia.org/wiki/Bearing_%28mechanical%29
And, yes... they ride on a film of oil, supplied by the engine oil pump.
http://en.wikipedia.org/wiki/Plain_b...id_lubrication
http://en.wikipedia.org/wiki/Oil_pum...tion_engine%29
OCR
Jan20-13, 03:01 PM   #5
Why do you think that "blow-by" would interfere with journal bearing lubrication?
Jan21-13, 08:30 AM   #6
the exhaust gases mix with the oil and make it more viscous than needed.
Now,the question is whether journal bearings would survive in such extreme conditions...why would engineers take the risk of the crosshead with a journal than the usual needle?
Jan26-13, 11:35 AM   #7
What is the risk?
Feb5-13, 01:03 AM   #8
I would imagine the load placed on the needle bearing would render it useless. The oil acts as a cushion to soften the impact as to prevent any damage from rod to crank
New Reply
Tags
bearings
Similar discussions for: Why is crankcase oil supplied to sleeve bearings?
Thread Forum Replies
ATV quad, front wheel ball bearings not tappered roller bearings. Mechanical Engineering 1
Crankcase Scavenging Mechanical Engineering 3
Crankcase Supercharging Question Mechanical Engineering 2
Bronze bearings vs brass bearings Mechanical Engineering 0
Thermal Expansion of Aluminium Sleeve over Steel shaft Introductory Physics Homework 1
