| New Reply |
Efficient way to find which element of Z*n has largest order? |
Share Thread | Thread Tools |
| Feb13-13, 07:26 AM | #1 |
Hey, I had two separate questions. (When I say Z*(n) I'm denoting the multiplicative group of integers mod n, namely, the units of Z(n))
First off, I know that if n is prime, that Z*(n) is cyclic. But this is not a biconditional statement. Is there any theorem which tells me conditions under which Z*(n) is not cyclic? I can't just say n is not prime so Z*(n) is not cyclic. Right? Second question - if I know that Z*(n) is cyclic, then I know it has a generator. But other than going through each and every element and multiplying them out, is there an efficient way to find out which elements are generators? Also, in the case that Z*(n) isn't cyclic (like say Z*(12)) is there a way to find which element has the highest order? If anyone can point me to the proper theorems, I would be extremely grateful! |
| Feb13-13, 12:16 PM | #2 |
Recognitions:
Start by thinking about the case where n = pq where p and q are both prime. (For example, n = 6)
When you see what is going on, generailze it to the case where n has more than two prime factors. |
| Feb13-13, 03:36 PM | #3 |
Recognitions:
Aleph Zero makes a good suggestion. It is not so trivial in general however, when there are repeated factors. There is a discussion starting on p. 48. of these notes, of when the group is cyclic:
http://www.math.uga.edu/%7Eroy/844-2.pdf In fact your question as to precisely how to identify generators is perhaps even less trivial. There may even be some open questions surrounding that matter, as I recall. |
| Feb13-13, 06:57 PM | #4 |
Thank you guys for the links and the responses!
I also found this: "Zn*, the multiplicative group modulo n, is cyclic if and only if n is 1 or 2 or 4 or pk or 2pk for an odd prime number p and k ≥ 1." But I did not see a proof provided for it. I think this might tie in with what you were saying AlephZero |
| Feb13-13, 10:25 PM | #5 |
Recognitions:
if you look at the links i provided you will find complete proofs of these facts.
| Feb13-13, 11:27 PM | #6 |
Yeah I have spent the last couple hours looking at the doc you provided and some other documents I've hunted down. Very helpful! I need to purchase a good number theory text book to have on hand it seems! Thank you again!
| New Reply |
| Thread Tools | |
Similar Threads for: Efficient way to find which element of Z*n has largest order?
| Thread | Forum | Replies | ||
| An efficient way to find perfect squares? | Linear & Abstract Algebra | 15 | ||
| A group of order 6 that has no element of order 6 is isomorphic to S_3 | Calculus & Beyond Homework | 4 | ||
| Group of order 100 with no element of order 4? | Calculus & Beyond Homework | 3 | ||
| find the largest mass that can sit on an incline without accelerating | Introductory Physics Homework | 1 | ||
| A group of order 2n conatins an element of order 2 | Calculus & Beyond Homework | 11 | ||
