Battery Puzzled, Something is wrong here.
  • Thread starter Thread starter Romodoc
    Battery
The discussion revolves around the functioning of batteries, particularly when connected in series. The initial explanation of electron flow between battery poles is questioned, especially regarding how electrons from multiple batteries reach the device without insulation. Clarification is provided that there are no insulations between batteries; they are connected via wires or direct contact. The internal processes of batteries maintain a constant voltage, and the flow of electrons is consistent regardless of whether they originate from a load or another battery. Overall, the conversation emphasizes the complexity of battery operation beyond simplified explanations.
Romodoc
Ok, this may be a very stupid question but I just can't find a right explanation.
I was reading about how a battery works (i.e. car or AA battery etc) and I found several videos giving the following explanation. (e-) are concentrated on one pole and a positively charged material is in the other pole with an insulation in between. Plug a light bulb and (e-) will rush from one pole to the other passing trough the spring, heating it up, photos are released etc etc, you get light! perfect. The explanation works here.
However, most electronics connect this batteries in series, and in this case, the basic explanation above doesn't make sense. If I have 3 batteries in series (A, B and C) in a device something like this:
device} [-/A/+] [-/B/+] [-/C/+] → {device
I can see how electrons go from C to A passing trough the device powering it. but how about electrons from A and B, how do they reach the device if there is an insulation.
Also according to this explanation, if put + of one battery next to - of another battery, it would drain one battery and leave the other with 2 negatively charged poles separated by the insulation in the middle. I know this is not the case, so I asume that explanation is a simplification of an obviously different process. Anyone could enlighten me?
There is no insulation, the batteries are connected with wires (or by a direct contact). If more electrons flow into the positive side of C, more electrons can leave the negative side of C.
There are more than enough electrons in the battery material ;).
There is a seperator (permeable membrane) in a some types of batteries to keep the plates from touching (shorting) and a electrolyte that conducts the ions that cross from one plate to the other and normally stop most electron flow. (that would cause self-discharge)
Lead Acid Battery: http://ecee.colorado.edu/~ecen4517/materials/Battery.pdf
If you think about it, there is no difference between a single battery powering a load (current out = current in) and the middle battery in the stack you drew (current out = current in). The same internal chemical processes are at work in the battery to keep a "constant" voltage across the battery terminals. The battery doesn't know the difference between electrons from a load and electrons from another battery. Either way it has to conduct I and maintain a constant voltage.
A perfect voltage source has 0 ohms resistance since it maintains the same voltage regardless of current.
As for the internal details, I really liked the lead acid battery link from nsaspook.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
11K
