Why Does the First Term in the Force Equation Between Current Loops Cancel Out?
The discussion revolves around proving that Newton's third law holds for the forces between two arbitrary current loops. The participant is using the Biot-Savart law and Lorentz force law to derive the force expression, leading to the realization that the force exerted by loop 1 on loop 2 is equal in magnitude and opposite in direction to that exerted by loop 2 on loop 1. A key point of confusion is why the first term in the derived force equation cancels out, which is clarified through an integral over loop 1 that evaluates to zero due to the properties of closed loops and the divergence theorem. The discussion emphasizes the importance of understanding these mathematical identities in the context of electromagnetic theory. The overall conclusion reinforces that Newton's third law is upheld in this scenario.
klawlor419
I am working on a problem involving force between two loops of current. The problem is to prove the for any arbitrary loops of current, Newtons third law holds true.
I understand the basics of the approach but I am having trouble seeing why a term goes to zero. The basic setup is to use the Biot-Savart law to predict the field of a segment of the current loop then to use the Lorentz force law to predict the force acting on a segment of the second loop.
This has the form,
$$d\mathbf{F}_{12}=\frac{\mu_0 I_1 I_2}{4\pi s^3}(d\mathbf{l_1}\times(d\mathbf{l_2}\times \mathbf{s}))$$
Which when simplified by the triple-product and integrated gives the following form,
$$ \mathbf{F}_{12}=\frac{\mu_0 I_1 I_2}{4\pi s^2}(\oint\oint d\mathbf{l_2}(d\mathbf{l_1}\cdot \hat{s}) -\oint\oint\hat{s}(d\mathbf{l_1}\cdot d\mathbf{l_2}))$$
Its easy enough to see right from here that F12=-F21 just by the fact that you pick up a minus sign by switching the separation vector. So in that sense the problem is solved, at least from what I see right now.
However I was looking in the Griffiths EM and apparently the first term on the left cancels out somehow and I can't figure why. (Problem 5.49) Any suggestions?
a couple of things.
1. s can't be pulled out of the integrals.
2. look at this term:
$$ \mathbf{F}_{12}=\frac{\mu_0 I_1 I_2}{4\pi}\oint\oint d\mathbf{l_2}\left(
d\mathbf{l_1}\cdot \frac{\hat{s}}{s^2}\right) $$
then realize that if we do the integral over loop 1 first, we have
$$ \oint d\mathbf{l_1}\cdot \frac{\hat{s}}{s^2} = \oint d_1\frac{1}{s} = 0. $$
where the subscript on 1 means I'm treating all the terms associated
with loop 1 as variables and freezing all terms associated with loop 2.
Just remember \nabla f \cdot d\mathbf{r} = df and you're integrating
over a loop that starts and end at the same place.
Ah nice, I see now. Thanks for the trick.
please could you explain why the integral over loop 1 is zero? I'm struggling to see your method.. :/
Theres an important identity involving one of the terms. Once you use that identity, you can deduce by divergence theorem that the entire term for loop 1 vanishes.
This has the form,
So if there is a loop current in a start say 10 light years away and I switch on a loop current in the Earth now the Newtons third law holds true.
Please, prove it with integrals and divergence theorem.
By the way I did not see any t (time) variable in your formulae.
Alva, the Biot Savart law uses the magnetostatic approximation. It doesn't apply in the far field and there is no time. This is a standard approximation, but it is an approximation.
