Stuck understanding Bernoulli's Principle, would love some help
Bernoulli's Principle explains how pressure and speed of air interact, but it isn't the primary reason sailboats can move faster than the wind. Sailboats cannot sail directly into the wind, but they can achieve higher speeds by utilizing the wind's energy efficiently. Low-drag vessels, like ice boats, can exceed wind speed due to minimal resistance, while certain vehicles can achieve speeds up to three times the wind speed by using wheels to drive a propeller. The key to these high speeds lies in the craft's ability to slow down the wind, whether through sails or propellers. Understanding these dynamics is crucial for grasping how wind-powered vehicles operate effectively.
avidstr
Hi all - I was having a debate with some students in my flipped class today and I can't wrap my head around Bernoulli's Principle as it relates to the sea.
Can anyone explain how Bernoulli's principle works with a sail boat? I don't know how the force vectors resolve to push a sail boat faster into the wind than with the wind.
Thanks so much for any help!
A sailboat can't sail directly upwind. A very low drag sailboat may be able to tach downwind such that the net downwind speed is greater than the wind speed. A better example would be an ice boat, where there is very little drag, and these can achieve downwind speed component much greater than the wind speed. There are also directly down wind faster than the wind (DDWFTW) vehicles that use the wheels to drive a propeller, and these can also go faster than the wind, with a full scale model achieving close to 3x wind speed with a wind around 10 mph. This works because the wind speed versus the ice / ground / water speed remains the same regardless of how fast the craft moves. Bernoulli equation approximates the amount of pressure versus speed of the air as the air is deflected by a sail or wing, but it's not the key reason for the high speed that these craft can achieve, other than for these vehicles to work the sail or drive train and propeller need to be efficient. Wind powered vehicles get their energy by slowing down the wind. It doesn't matter if the wind is slowed down directly by the sail or propeller, or slowed down due to an upwind component of the wash of air diverted by a sail or accelerated by a propeller.
Other threads with links to even more threads:
https://www.physicsforums.com/showthread.php?t=562993
https://www.physicsforums.com/showthread.php?t=421733
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
