Elevating my Understanding of Electrical Engineering
Alec is seeking recommendations for a well-written book on Electrical and Mechanical Engineering that explains the underlying principles of processes, particularly in building custom radio transmitters and receivers. He emphasizes the need for practical applications rather than beginner-level content. Forum members suggest starting with foundational texts to solidify his understanding of electrical engineering basics before progressing to more advanced materials. The ARRL Radio Amateur's Handbook is recommended as a good resource for high-level concepts and hobby electronics. A strong grasp of engineering fundamentals, including the necessary math and models, is essential for deeper learning and circuit design.
Alec049
Hello PhysicsForum's,
Over the last couple months I've been studying electrical engineering and I think I have pretty good grasp of the basics. I am a computer programmer so dealing with math and logical problems are not foreign to me, however, I've hit a road block. I realize now that I can't learn Electrical Engineering the same way I learned programming. I need a well written book. So, I was wondering if any of you could recommend me a book on Electrical/Mechanical Engineering.
I'm looking for a book that:
*Focuses heavily on the why the processes described works.
*Has some real practical use and isn't just for beginners or idiots.
*Explains in-depth on how to build custom radio transmitters and receivers, and explains why they work.
*Does not focus on things such as fixing household electronics.
As I said before, I'm a computer programmer and I'd really like to merge my understanding for software with the hardware side of things. I believe this could many doors for me, and I really appreciate any help I get.Thanks,
Alec
ARRL Radio Amateur's Handbook gets my vote.
Alright awesome, thanks Jim, I'm on my way to the library now to see if I can find a copy of it.
I would say if you are truly interested in learning the engineering side to the extent of understanding the why a circuit works, you need to start with the basics of Electrical Engineering. You should find the book used in an intro to Electrical Engineering so you might begin to understand how to analyze a circuit.
I agree that Jim has given you a suggestion of a good source to understand from a high level and some very basic "hobby" electronics information. You will need to determine if your interest in learning is from a hobby side where you will only construct and use information that others design, or if you want to design a circuit from the ground up and know why all the items are used.
Engineering is mainly about the understanding of how to analyze with the math behind and the models utilized. So as is hinted at above by others, if you understand the Engineering basics (the models and math), then continue with the Engineering text.
In my opinion.
mitch
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
