Can someone please explain the elevator paradox?
The elevator paradox involves the probability of an elevator being above or below a waiting passenger in a multi-floor building. When the elevator is equally likely to be on any floor, if there are more floors above the passenger, the likelihood of the elevator arriving from above increases. This leads to the conclusion that, on average, the elevator will take longer to arrive when the passenger is waiting on a lower floor compared to a higher one. The discussion highlights a preference for simpler explanations over complex ones, particularly criticizing Wikipedia's approach. Understanding the paradox relies on basic probability principles rather than complicated theories.
Nerdydude101
I tried searching it up but the only good place i found was wikipedia that actually talked about it and i hate wikipedia because it tries to explain complex things in complex ways instead of making them simple. Thanks!
Mathematics news on Phys.org
What is the elevator paradox?
Yeah
This paradox really isn't complicated. Assume that when you arrive and begin to wait for the elevator the elevator is on a random floor in the building (for simplicity assume equal probability of being on each floor). If the elevator is randomly above you then it will have to come down to get you, if it is randomly below you then it will have to come up to get you. If there are more floors above you than below you then the probability of it being above is greater than the probability of it being below and therefore the probability of a downwards elevator is greater than an upwards elevator.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
