Thermal Properties: Pressure, Volume, Temp question
In summary, the Jaguar XK8 convertible has an eight-cylinder engine. At the beginning of its compression stroke, one of the cylinders contains 499 cm cubed of air at atmospheric pressure (1.01E5 Pa) and a temperature of 27.0 degrees C. At the end of the stroke, the air has been compressed to a volume of 46.2 cm cubed and the gauge pressure has increased to 2.72E6. The final temperature is 66.8 degrees C.
wcbryant87
A Jaguar XK8 convertible has an eight-cylinder engine. At the beginning of its compression stroke, one of the cylinders contains 499 cm cubed of air at atmospheric pressure (1.01E5 Pa) and a temperature of 27.0 degrees C. At the end of the stroke, the air has been compressed to a volume of 46.2 cm cubed and the gauge pressure has increased to 2.72E6.
What is the final temperature
P1*V1/T1 = P2*V2/T2
I followed the equation that I posted above. Here is what it looked like.
(1.01E5 * 499 cm cubed)/ 27 = (2.72E6 * 46.2)/x
Solving for x, I got x = (2.72E6*46.2)/1866629.63 = 66.8 degrees C
Problem is, that answer is apparently wrong. Am I missing something here?
Thanks for the help!
Try changing your temperature to kelvin :)
well it wants the answer in celcius. Does that equation have to be done with Kelvin units?
Were you given that equation? As you won't find T2 like that. Even if you use kelvin as the pv/pv is a ratio, it won't make any difference.
Hint: Expansion and compression is isentropic.
No I wasn't given any equation. I thought that that one would work though because I was only missing one variable.
Do I use pv=nrt?
If you've got a book, look up isentropic compression.
pv^gamma = constant.
where gamma is the polytropic constant you'll have to find the relationship between temperature and anther variable.
Thats the Adiabatic process.
Calculate the mass of air in the cylinder from pv=mRT
Constants for air Cp=1005J/kgK, Cv=718J/kgK R=287J/kgK, calculate gamma from these.
Reaarange the equation for an adiabatic process to find T
its both acutally, as isentropic is adiabatic and reversible. to find the temperatre after compression you don't need the mass in the cylinder as it comes out in the wash.
the relationships for isentropic processes for ideal gases are listed in any thermo textbook. but as this is homework help I am not going to just give them out.
1. What are thermal properties?
Thermal properties refer to the characteristics of a material that determine how it responds to changes in temperature. These properties include thermal conductivity, specific heat capacity, thermal expansion, and thermal diffusivity.
2. How does pressure affect thermal properties?
Pressure can affect the thermal properties of a material by compressing or expanding it, which can in turn change its density and therefore its ability to conduct heat. In general, increased pressure can lead to increased thermal conductivity and specific heat capacity.
3. What is the relationship between volume and thermal properties?
The relationship between volume and thermal properties is complex and depends on the specific material and conditions. For some materials, an increase in volume can lead to a decrease in thermal conductivity, while for others it may have no significant effect.
4. How does temperature affect thermal properties?
Temperature is a key factor in determining the thermal properties of a material. Generally, as temperature increases, so does thermal conductivity and thermal expansion, while specific heat capacity may decrease. However, these relationships can vary for different materials.
5. What is the significance of understanding thermal properties?
Understanding thermal properties is crucial for a variety of applications, from designing efficient heating and cooling systems to selecting appropriate materials for specific environments. It also plays a role in fields such as materials science, thermodynamics, and environmental science.
