Magnetoresistance and Fermi surfaces
In summary: I don't know how it works.In summary, there seems to be a relation between Fermi surfaces and magnetoresistance, but because I don't have a clear picture of Fermi surfaces, I have difficulty understanding this relationship. Also, I have heard about open and close Fermi surfaces and saturation of magnetoresistance, but I can't find enough explanation about it. I will appreciate any clarification. Thanks
ShayanJ
Insights Author
604
There seems to be relation between Fermi surfaces and magnetoresistance, but I guess because I don't have a clear picture of fermi surfaces,I have problem understanding this relationship.
Also I have heard about open and close fermi surfaces and saturation of magnetoresistance which I can't find enough explanation about.
Thanks
I've been searching different books and sites on the subject but non of them give a satisfactory proof of the saturation of magnetoresistance in the directions that the fermi surface are closed.Can someone explain?
Thanks
Try to explain me how you think this all works and you get my comments for free!
Well,The point is,I don't know how it works!
I can only suggest you to take a look at chapters 11 and 12 of:http://www2.physics.ox.ac.uk/sites/default/files/BandMT1112_CompleteSet.pdf
It helps you into the subject.
There is also chapter 12 of solid state physics by Ashcroft and Mermin.
You can find explanations about the subject in other books and websites too,but non that I found had a full and satisfactory proof of magnetoresistance saturation in the directions that the Fermi surface is closed.
Also,these texts tell you what I know about it and how I think.
Have a look at:
arXiv:0907.2021v1 [cond-mat.mes-hall]
They discuss the high and low field limit.
DrDu said:
Have a look at:
Thanks for introducing the paper,it seems so useful...But it still doesn't give me the thing I want.
In the high field limit,it gives the current density by the following formula:
[itex]
\vec{J}=-e \frac{\vec{E}\times\vec{B}}{B^2}n
[/itex]
To make things simple,let's have [itex] \vec{E}\cdot\vec{B}=0 [/itex],So we will have [itex] J=-\frac{ne}{B}E \Rightarrow |\sigma|=\frac{ne}{B} \Rightarrow |\rho|=\frac{B}{ne} [/itex] which is proportional to B and so doesn't approach a constant as [itex] B\rightarrow \infty [/itex]
I have the same problem with the argument presented in Ashcroft and mermin.
But in http://www2.physics.ox.ac.uk/sites/default/files/BandMT1112_CompleteSet.pdf ,there is another problem.
First,in section 11.3.1,the conductivity tensor is derived and then inverted to give the resistivity tensor.It turns out that [itex] \rho_{xx}=\rho_{yy}=\rho_0 [/itex] and [itex] \rho_{yx}=-\rho_{xy}=-\frac{B}{ne} [/itex].
Then in section 11.3.3,[itex] \rho_{xx}[/itex] is said to tend to a constant as [itex] B \rightarrow \infty [/itex]!
Also,[itex] \sigma_{xx}=\sigma_{yy}=\frac{\sigma_0}{1+\omega_c^2 \tau^2} (\omega_c=\frac{eB}{m})[/itex] is derived in section 11.3.1 regardless of the shape of the fermi surface.But in section 11.3.3 it is argued that it behaves differently for closed and open fermi surfaces.
If only the inconsistencies are cured and the explanations are clarified a little,then this last paper may help.
Well, I suppose, the question of million is what is the form of the cyclotron frequency in the case of an open fermi surface?
For an open surface, the electron will not perform a cyclic motion at all but will be driven along a, maybe wiggly line. Hence the frequency must be 0.
I suppose this is formally due to the effective mass - when averaged over the orbit - being infinite.
That's reasonable but if you take a look at the derivation of equation 11.30,it is said that [itex] \sigma_{yy}=C [/itex] and [itex] \sigma_{xx}=AB^{-2} [/itex] where A and C are constants.If frequency was zero,both would be constant because they're equal!In fact the expression for them has no parameter which isn't in common between them so I can't understand how one is a constant in the limit and the other is not!
And in the first paragraph of section 11.3.3,it is said that [itex] \sigma_{yy} [/itex] and [itex] \sigma_{xx} [/itex] both vary as [itex]B^{-2}[/itex].This is OK but if we use previous formulas,then we're not talking only about closed orbits.So the derivation of such a behavior should use something else which in that part of the text,seems to be the zero average of the velocity in the plane perpendicular to B and equations 11.27 and 11.28 in the high magnetic field limit.But that just suggests that they should vary as [itex] B^{-n}(n>0) [/itex] and there should be another way for determining n.
To be honest,I lost my hope on this paper!
I am not sure either. However the equality of sigma_xx and sigma_yy is derived in 11.1 under the explicit assumption of an isotropic and energy independent effective mass.
I think it is this assumption which breaks down when you have an open FS.
1. What is magnetoresistance?
Magnetoresistance is the change in the electrical resistance of a material when a magnetic field is applied. It is caused by the interaction between the magnetic field and the charge carriers in the material.
2. What is the difference between positive and negative magnetoresistance?
Positive magnetoresistance refers to an increase in resistance when a magnetic field is applied, while negative magnetoresistance refers to a decrease in resistance. This difference is due to the type of charge carriers and their mobility in the material.
3. What are Fermi surfaces?
Fermi surfaces are regions in the reciprocal space of a material where the energy levels of the electrons are filled up to the Fermi energy. They represent the boundary between occupied and unoccupied energy states and are important for understanding the electronic properties of materials.
4. How does magnetoresistance relate to Fermi surfaces?
The shape and size of the Fermi surface can affect the magnetoresistance of a material. In some materials, the Fermi surface changes in the presence of a magnetic field, leading to changes in the mobility of the charge carriers and therefore the resistance.
5. What are some applications of magnetoresistance and Fermi surfaces?
Magnetoresistance and Fermi surfaces have important applications in fields such as magnetism, superconductivity, and semiconductor devices. They are also used in technologies such as magnetic sensors, data storage, and magnetic resonance imaging (MRI).
  • Atomic and Condensed Matter
