Find the sum in this given question very interesting and analytical
In summary: and that leads to a wrong answer.[2^0/3]=0[2^1/3]=1[2^2/3]=2[2^3/3]=2[2^4/3]=4[2^5/3]=4[2^6/3]=8[2^7/3]=8[2^8/3]=16[2^9/3]=16[2^10/3]=32[2^11/3]=32[2^12/3]=64[2^13/3]=64[2^14/3]=128[2^15/3]=
Was this question really interesting ??
  • Total voters
  • Poll closed .
Vishalrox
Find the sum of : [2[itex]^{}0[/itex]/3] + [2[itex]^{}1[/itex]/3] + [2[itex]^{}2[/itex]/3] + [2[itex]^{}3[/itex]/3] + [2[itex]^{}4[/itex]/3] + ... + [2[itex]^{}2008[/itex]/3]
where [] is the greatest integer function symbol...
if the question is not clear here is the question..
Find the sum of : [(2^0)/3] + [(2^1)/3] + [(2^2)/3] + [(2^3)/3] + ... [(2^2008)/3]
When we divide a number by 3 there are three options:
1. It is exactly divisible
2. Remainder=1
3. Remainder=2
Exact divisibility does not apply to powers of two
Now,
[tex]{2}^{2n}{=}{4}^{n}{=}{(}3+1{)}^{n}[/tex]
When the above quantity is divided by 3 the remainder is one[We get this from binomial expansion]
Therefore
[tex]{2}^{2n}{=}{3k}{+}{1}[/tex]
[tex]{[}\frac{{2}^{2n}}{3}{]}{=}{k}[/tex]
[tex]{k}{=}\frac{{2}^{2n}{-}{1}}{3}[/tex]
Again,
[tex]{2}^{2n+1}{=}{2}{[}{4}^{n}{]}{=}{2}{(}3+1{)}^{n}[/tex]
When the above quantity is divided by 3 the remainder is 2[We get this from binomial expansion]
Therefore
[tex]{2}^{2n+1}{=}{2}{*}{3k}{+}{2}[/tex]
[tex]{[}\frac{{2}^{2n+1}}{3}{]}{=}{2}{*}{k}[/tex]
[tex]{2k}{=}\frac{{2}^{2n+1}{-}{2}}{3}[/tex]
For the above series terms in the first two terms cannot be expanded in the form [3+1]^2n
We write the values directly—>0 +0
Third term=[{2^(2*1)}/3]=1
Fourth term=[{2^(2*1+1)}/3]=2
Fifth term=[{2^(2*2)}/3]
Sixth term=[{2^(2*2+1)}/3]
The value of n remains the same in a pairwise manner as shown above.
From the third term onwards we take to different series
1. [tex]\Sigma\frac{{2}^{2n}{-}{1}}{3}[/tex]
Summation running from 1 to 1004
2. [tex] \Sigma\frac{{2}^{2n+1}{-}{2}}{3}[/tex]
Summation running from 1 to 1003
Sum=[tex]\frac{4}{9}{[}{4}^{1004}{-}{1}{]}{+}\frac{8}{9}{[}{4}^{1003}{-}{1}{]}{-}{1004}[/tex]
2. Remainder=1
3. Remainder=2
Now,
Therefore
Again,
Therefore
Nice method...but i just expanded a few terms and i observed the oddth and eventh terms...the oddth term = (previous term * 2)+1...while eventh term = previous term*2...and there are 2009 terms total...the difference between the consecutive oddth terms incremented in GP...1,5,21,85...in the same way for eventh terms too...so consolidating all these...
sum(2^(2n) / 3 - (1/3) + 2^(2n + 1) / 3 - 2/3 , n = 0 , n = 1004) - (2^(2008) / 3 - (1/3))
sum((1/3) * 4^(n) - (1/3) + (2/3) * 4^(n) - (2/3) , n = 0 , n = 1004) - (2^2008 / 3 - (1/3))
(1/3) * sum(4^n + 2 * (4^n - 1) , n = 0 , n = 1004) + 1/3 - (1/3) * 2^(2008) =>
(1/3) * (sum(4^n + 2 * 4^n , n = 0 , n = 1004) - 1 * 1005) + (1/3) - (1/3) * 2^(2008) =>
(1/3) * (3 * sum(4^n , n = 0 , n = 1004) - 1005) + (1/3) - (1/3) * 2^(2008) =>
sum(4^n , n = 0 , n = 1004) - 1005 + (1/3) * (1 - 2^(2008)) =>
(4^(1005) - 1) / 3 + (1/3) * (1 - 4^(1004)) =>
(4 * 4^(1004)) / 3 - (1/3) + (1/3) - 4^(1004) =>
(4/3) * 4^(1004) - 4^(1004) =>
(1/3) * 4^(1004)
So which answer is correct ?
Hello Vishal!
So far as your result is concerned the value is not integral.
[tex]\frac{1}{3}{*}{4}^{1004}[/tex]
[tex]\frac{1}{3}{*}{(}{3+1}{)}^{1004}[/tex]
[tex]\frac{1}{3}{*}{(}{3k}{+}{1}{)}[/tex]
As for my result:
[tex]{4}^{1003}{-}{1}{=}{3k}[/tex] -------------- (1)
Again,
[tex]{4}^{1004}{-}{1}{=}{4}{*}{4}^{1003}{-}{1}[/tex]
[tex]{=}{4}{*}{(}{3k}{+}{1}{)}{-}{1}[/tex]
[Equation (1) has been used to get this from the previous step]
[tex]{=}{12k}{+}{3}[/tex]
Therefore,
Sum=
[tex]\frac{4}{9}{(}{12k}{+}{3}{)}{+}\frac{8}{9}{3k}{-}{1003}{-}\frac{1}{3}[/tex]
[tex]{=}\frac{{72k}{+}{12}}{9}{-}{1003}{-}\frac{1}{3}[/tex]
[tex]{=}{8k}{+}{1}{-}{1003}[/tex]
The above result is integral
[The result in the last line of post #2 has been modified:modification in post #6]
ooh...nice...got it...!
I think I have a mistake. I am checking.
Corrected Sum=[tex]\frac{4}{9}{[}{4}^{1004}{-}{1}{]}{+}\frac{8}{9}{[}{4}^{1003}{-}{1}{]}{-}{3010}{/}{3}[/tex]
[tex]{=}\frac{4}{9}{[}{4}^{1004}{-}{1}{]}{+}\frac{8}{9}{[}{4}^{1003}{-}{1}{]}{-}{1003}{-}{1}{/}{3}[/tex][I have got 3010/3 by evaluating [1004+2*1003]/3 . You will get this from the summations 1 and 2 in post #2]
I think in the first post u hv made a mistake...wait...am solvin...am gettin a similar but diff answer..!
[a/3] is not [1/3][a], and is not [a]/3, so if you people are factoring out 1/3 i think you should reconsider.:smile:
I think i got this one. Compute the first few terms of [2^n/3]
[edit] As Anamitra points out below i confused floor with cieling function, however a slight adjustment fixes the result. THANK YOU ANAMITRA!
0 + 0 + 1 + 2 + 5 + 10 + 21 + 42 + 85 + 170 + 341 + 682 +1365, ...it is clear that this sum has 2009 terms. Group the first 2008 two at a time in order.
(0+0) + (1+2) + (5+10) + (21+42) + (85+170) + (341+682) + ...+ [2^2008/3] it is clear that each sum in parenthesis is 1 less than a power of 4. There are 1004 such sums.
(4^0-1) + (4^1-1) + (4^2-1) + (4^3-1) + (4^4-1) + ...+ (4^1003-1) + [2^2008/3] re-arrange
-1004 + (4^0 + 4^1 + 4^2 + 4^3 + 4^4 + ... + 4^1003) + [2^2008/3]
The sum of consecutive powers of 4, starting at exponent zero up to n is well known, (4^(n+1)-1)/3 i will derive it later.
-1004 + (4^1004-1)/3 + [2^2008/3]
that nasty last expression isn't so nasty if you rewrite it as [4^1004/3] and realize SUBTRACTING 1 from any power of 4 makes it divisible by 3 AND gives the floor of 4^n/3.
-1004 + (4^1004-1)/3 + (4^1004-1)/3 = -1004 + (2(4^1004)-2)/3 = -1004 + (2^2009-2)/3
SUBTRACTING 1 from any even power of 2 makes it divisible by 3 so this gives a whole number:smile:
So the final answer is...
(2^2009 - 2)/3 -1004
DERIVATION:
S = 4^0 + 4^1 + 4^2 + ... + 4^n
multiply by 4
4S = 4^1 + 4^2 + 4^3+ ... + 4^n + 4^(n+1)
subtract
4S - S = 4^(n+1) - 1
S = (4^(n+1) -1)/3 :wink:
P.S. Thanx to Anamitra for pointing out my confusion, from now on let's just call it the floor function to eliminate confusing 'greatest integer' nonsense.:smile:
Hi Agentredlum, [x] is the greatest integer less than or equal to x. They call it the"floor"
But you have taken the ceiling--> smallest integer greater than or equal to x.
Calculation of terms[GIF]
[tex]{[}\frac{{2}^{1}}{3}{]}{=}{0}[/tex]
[tex]{[}\frac{{2}^{2}}{3}{]}{=}{1}[/tex]
[tex]{[}\frac{{2}^{3}}{3}{]}{=}{2}[/tex]
[tex]{[}\frac{{2}^{4}}{3}{]}{=}{5}[/tex]
[tex]{[}\frac{{2}^{5}}{3}{]}{=}{10}[/tex]
[tex]{[}\frac{{2}^{6}}{3}{]}{=}{21}[/tex]
The series is:
0+0+1+2+5+10+21+42+85...The the terms of the ceiling you have got:
1+1+2+3+6+11+22+43+86...
For the adjustment in the last term you seem to have taken the floor.
I hope the difference is clear now.
Caculations
[tex]{2}^{2n}{=}{(}{3+1}{)}^{n}{=}{3k+1}[/tex]
[tex]{2}^{2n+1}{=}{2}{(}{3+1}{)}^{n}{=}{6k+2}[/tex]
If [] denotes the ceiling:
[tex]{[}\frac{{2}^{2n}}{3}{]}{+}{[}\frac{{2}^{2n+1}}{3}{]}[/tex]
[tex]{=}{k+1}{+}{2k+1}[/tex]
[tex]{=}{3k+2}[/tex]
[tex]{=}{2}^{2n}{+}{1}[/tex]
[Since [tex]{3k}{=}{2}^{2n}{-}{1}[/tex] ...From the first step]
For n=0,1,2,3,4...
the formula gives:
2=1+1
5=2+3
17=6+11
65=22+43 etc.
This confirms your observation analytically.
Anamitra said:
Caculations
For n=0,1,2,3,4...
the formula gives:
2=1+1
5=2+3
17=6+11
65=22+43 etc.
Please take a look at my edited post #9, i think i fixed the proof.:biggrin:
LOL By confusing floor with ceiling my technique solved both problems. I guess i made a 'right' mistake. The same question but ceiling instead of floor gives... [2^0/3] + [2^1/3]+ [2^2/3]+ ... + [2^2008/3] = (2^2009 + 1)/3 + 1004:smile:
I have got the same thing in post #6 as you have got finally.
[tex]{=}\frac{{4}^{1005}}{9}{+}\frac{{2}{*}{4}^{1004}}{9}{-}{12}{/}{9}{-}{3010}{/}{3}[/tex]
[tex]{=}\frac{{4}^{1004}}{9}{(}{4+2}{)}{-}{12}{/}{9}{-}{1004}{+}{2}{/}{3}[/tex]
[tex]{=}\frac{{2}{*}{4}^{1004}}{3}{-}{2}{/}{3}{-}{1004}[/tex]
[tex]{=}\frac{{2}{*}{4}^{1004}{-}{2}}{3}{-}{1004}[/tex]
[tex]{=}\frac{{2}^{2009}{-}{2}}{3}{-}{1004}[/tex]
But your method is comfortable/easier to work with.The observation you made is quite interesting.But you should always try to establish it in a general manner from theoretical considerations. In this case the general proof is simple enough. You can always follow a technique similar to the one in post #11 or some suitable alternative.
The summations 1 and 2 in post #2 can enable one to calculate two distinct series[separately] in relation to the floor function.
Similar summations can be developed for the ceiling function also.
One of course could look for other formulas arising out of some interesting pattern in the terms comprising the series.
[One could also think of replacing the divisor 3[in the series of post #1] by some other natural and follow some technique similar to the one shown in post #2 to develop summation formulas.]
Thank you for your notations and indications. Can you please post a picture? I am using my BRAIN to decode TeX but i would rather use my PINKY. My browser does not decode TeX and sometimes it's hard for me to understand posted formulas. Sorry to put you into too much trouble.:smile:
Hello!
I have uploaded a .bmp file for you.
Anamitra said:
Hello!
NICE! THANK YOU VERY MUCH!:smile:
Hey...gud one...very interesting.
1. What is the purpose of finding the sum in this given question?
The purpose of finding the sum in this given question is to practice and improve your analytical and mathematical skills. It also helps to develop critical thinking and problem-solving abilities.
2. How do you approach finding the sum in this given question?
To find the sum in this given question, you should first carefully read and understand the question. Then, identify the numbers that need to be added together. Next, use the appropriate mathematical operations to calculate the sum. Finally, check your answer to ensure accuracy.
3. What are some strategies for finding the sum in this given question?
Some strategies for finding the sum in this given question include breaking down the problem into smaller parts, using mental math techniques, and checking your work for errors. You can also use a calculator or pen and paper to help with calculations.
4. Are there any common mistakes to avoid when finding the sum in this given question?
Yes, some common mistakes to avoid when finding the sum in this given question include misreading the question, using the wrong mathematical operations, and making calculation errors. It is also important to double-check your work and make sure you are using the correct numbers.
5. How can finding the sum in this given question benefit me in the real world?
Finding the sum in this given question can benefit you in the real world by improving your overall mathematical skills, which are essential for many careers, such as in science, engineering, finance, and more. It can also help you in everyday situations, such as calculating expenses, understanding data and statistics, and making informed decisions.
  • Linear and Abstract Algebra
