Just a Little Mind Game re: Superluminal Neutrino Velocities
In summary, the conversation revolved around the idea of repulsive gravitation and its possible connection to dark energy. The participants discussed the possibility of particles under the influence of repulsive gravity exhibiting characteristics of relative negative mass, and whether this could lead to superluminal velocities. However, one person noted that negative mass would not necessarily result in superluminal speeds. Another participant brought up the observation of neutrinos from supernova 1987A and how it contradicts the claims of the OPERA experiment. The conversation ended with one person conceding the point and requesting a link for further information.
BadBrain
196
By now, I've listened several times to Brian Greene's talk about the OPERA experiment. And, although I largely agree with him, there's one nagging question I have:
Gravitation was, at a time soon following the Big Bang, a repulsive force.
The existence of "Dark Energy" suggests the persistence of repulsive gravitation in our universe.
If gravitation was once, and, within certain contextual constraints regulating our universe, apparently still is, a repulsive force, does it not make perfect sense, well within the bounds of Einsteinian Special Relativity, that particles under the influence of "Dark Energy"/repulsive gravity would, although possessing mass, exhibit the characteristics of RELATIVE negative mass, with respect to our observational perspective? Relative negative mass would REQUIRE relative superluminal velocity of particles under the influence of repulsive gravity/"Dark Energy".
Am I an idiot? (I sure feel like one right now!)
Does anybody have any other idea?
Space news on Phys.org
Inflation (right after the big bang) and accelerated expansion (dark energy) are not the same as ordinary gravity, although there is some connection through general relativity. Ordinary gravity is attractive, as you well know.
Correct you are. But the fact remains that gravitation was, and, in certain cases, still is, a repulsive force. The only thing I can think of that would allow for this apparent anomaly is for the particles under the influence of this repulsive gravity to exhibit characteristics of relative negative mass, while, simultaneously, possessing positive mass sufficient to account for the "missing mass" in our universe.
I don't see any connection here.
But if you ask me, the observation of the neutrinos from supernova 1987A pretty much entirely rules out the possibility of the OPERA experiment being valid.
OK, let me test that. The neutrino emission from SN1987A preceded the visible light emission by three hours. How do I find out the radial size of the star so I can model the interval between core collapse and the shockwave reaching the surface? Do stellar seismic events travel at the speed of light, or some other speed? (Obviously it must be less than the speed of light in a vacuum, as a star is hardly a vacuum.)
As I said, Professor Greene is most likely right, but I'm just trying to figure out what the odd chance would look like.
In fact, negative mass would not amount to superluminal speeds. That would be negative squared mass (or, equivalently, imaginary mass).
It's not necessary to delve into the details of the physics of the supernova. Just note that SN1987A occurred 168,000 light years away. Three hours is two parts in a billion of the travel time. So the simple, back-of-the-envelope estimate makes it so that the speed of neutrinos differ from the speed of light by no more than two parts in a billion. You can get better than this, obviously, by taking into account the physics of the supernova in some detail, but ignoring it is good enough for our purposes here.
The OPERA team claims that these neutrinos differ from the speed of light by one part in 40,000. I don't see any possible way to reconcile these two results, even taking into account the fact that the neutrinos measured by OPERA had higher energy.
Parlyne and Chainoth:
You're both correct. I concede the point.
I'd like follow that. Link please?
Chainoth:
If the time difference between the observation of neutrinos from SN1987A and the observation of visible light from that event is not calculable with finesse equivalent to the OPERA experiment, due to the limitations on resolution obviously operating at such a vast space-time scale, than how does the SN1987A event have any bearing on the validity of the OPERA results? Are man-made scientific instruments really capable of producing energies greater than those produced by massive stellar events? Or is the energy bleed-off involved in motion across such vast distances sufficient to account for lower-energy naturally-propelled neutrinos as compared with neutrinos propelled by man-made devices measured just a few hundred kilometers from their source?
BadBrain said:
Chainoth:
I don't understand what you mean. It is far, far easier to get a fine-grained measurement of the relative speed of light and neutrinos from SN1987A. The difference is travel time. The total travel time between CERN and the OPERA detector was a mere 2.4ms. So in order to detect differences in the travel time, you need your timing apparatus to detect differences that are vastly, vastly smaller than 2.4ms.
By contrast, SN1987A occurred some 168,000 light years away, so you can get the exact same accuracy as the OPERA measurement by being able to detect the arrival time within a span of 4.2 years. So in practice, you just do not need obscenely-accurate estimates of the arrival time from SN1987A. A few hours' discrepancy leads to a vastly more accurate estimate of the relative speed of neutrinos and light than can realistically be done with an OPERA-type experiment.
Total energies, no, certainly not. But typical energy per particle? Absolutely, because the typical energy per particle of those particles emitted from a supernova usually isn't that great. Though I should mention that there do exist particles that we detect here on Earth which have energies more than a million times greater than can be produced by the LHC. See here:
http://en.wikipedia.org/wiki/Ultra-high-energy_cosmic_ray
Thanks! So the OPERA measurements were taken by means of instruments proportionally too large for the objects whose activity they were measuring, and over a "race course" too short, to allow for either instrument resolution or sample size to produce a reliable result.
Matter concluded.
Matter concluded.
Well, it's not so much that it's too large, but rather that the distance between CERN and OPERA is too small, so that it is incredibly difficult to get the timing right. It's a very tricky, finicky experiment, and the best guess right now is that something is wrong with their timing apparatus.
The speed of light in a non vacuum is different to the speed of light in a perfect vacuum. Space is not a perfect vacuum so could this explain the delta between the speed of neutinos and the speed of light from supernova?
I know that, as I already stated in my post above: "Obviously it must be less than the speed of light in a vacuum, as a star is hardly a vacuum.".
Also, you may be missing the point that neutrinos are emitted from supernovae at the time of core collapse, whereas visible light isn't emitted until the countercoup from the core collapse strikes the stellar surface. Therefor, visible light will always follow the neutrinos.
The difference in the speed of light is due to interactions between the light and the matter is it moving through. So no, it can't explain this discrepancy because neutrinos hardly interact at all with matter.
Yes the neutrinos are not slowed so I thought this explains why the neutinos arrive a few hours earlier than the light?
Perhaps the speed of light should be re-defined as the speed of neutrinos since we know that they cannot ever get slowed down by any matter along the way?
A new yardstick reference perhaps?
Perhaps the speed of light should be re-defined as the speed of neutrinos since we know that they cannot get slowed by any matter along the way?
The speed they're being compared to is the speed of light in a vacuum. But no, it can't be something simple as this because it wouldn't agree with our experiments with high-velocity matter.
I was wondering if the discrepancy could be due to the presence of a gravity well of rather significant depth compared to the distance traveled between the source and detector?
If we observe a supernova on the far side of a massive galaxy cluster, might the neutrino travel time have been lessened by some mechanism which we wouldn't have seen from the SN1987a event due to the flatter spacetime along the path?
Well, considering the discrepancy is seen on a terrestrial experiment, it can't be something like an unknown gravitational field.
Well, if you're talking about SN1987A, then photons and neutrinos interact in pretty much the same way with regard to gravity.
I mean the neutrinos here were moving through a not insignificant gravity well as they traveled to the detector, while SN1987a did not.
That suggests that using one to test the other isn't the most sound argument, doesn't it?
I don't think that criticism makes any sense whatsoever.
The SN1987A result is a highly sensitive measurement of the relative speed of light and neutrinos, because it was 168,000 light years away and we were able to detect both from it. Gravity differences are irrelevant because both light and neutrinos saw the same basic gravitational fields during the transition, and are affected in pretty much the same way by gravity. Given the SN1987A result, it is highly unlikely that neutrinos travel faster than light.
1. What are superluminal neutrino velocities?
Superluminal neutrino velocities refer to the hypothetical phenomenon in which neutrinos, a type of subatomic particle, are able to travel faster than the speed of light.
2. Is it possible for neutrinos to travel faster than light?
As of now, there is no concrete evidence that supports the existence of superluminal neutrino velocities. The phenomenon was observed in a 2011 experiment at CERN, but was later found to be due to a measurement error. The speed of light is considered to be the universal speed limit according to the theory of relativity, making it highly unlikely for neutrinos to surpass it.
3. What causes superluminal neutrino velocities?
The cause of superluminal neutrino velocities is still unknown. Some theories suggest that it could be due to a violation of the theory of relativity, while others propose the existence of extra dimensions or the possibility of neutrinos traveling through a shortcut in space-time. However, these are all speculative and have not been proven.
4. What implications would superluminal neutrino velocities have on physics?
If superluminal neutrino velocities were proven to be real, it would have significant implications on our understanding of physics and the laws of the universe. It would challenge the theory of relativity and possibly lead to new discoveries and advancements in the field of physics.
5. Are there any ongoing studies or experiments related to superluminal neutrino velocities?
There are ongoing studies and experiments being conducted to further investigate the possibility of superluminal neutrino velocities. However, due to the lack of concrete evidence, most physicists are still skeptical about its existence and are focusing on other areas of research in the field of particle physics.
  • Cosmology
  • Cosmology
