Rate of heat loss with two thermal conductivity values
I have no idea if I use the right Tl and Tr as initial conditions but I am sure of the rest.Thank you for your time and patience.In summary, the problem is to calculate the rate of heat loss through a fireclay refractory wall with a thickness of 0.1m. The furnace operates at 1000C while the outside temperature is 100C. The thermal conductivity of the clay is 1.5 at 1000C and 1.1 at 100C. By using the equation for rate of heat loss per square meter, q=-kdT/dx, and assuming a linear relationship between k and temperature, an average k value of 1.3 is obtained. However
flying fish
47
Strangely, this is for a Mat Sci Class. It is probably not as complicated as I am making it out to be, but the book has no suggestions on how to handle this problem.
Calculate rate of heat loss through a fireclay refractory wall of wall with thickness .1m. Furnace operates at 1000C and outside is at 100C. Thermal conductivity of the clay at 1000C is 1.5, and 1.1 at 100C
Rate of heat loss per square meter = q = -kdT/dx
dT = 900C
dx = .1m
k(1000) = 1.5
k(100) = 1.1
(q is what I am trying to find)
After realizing that there are two thermal conductivity values, so I could not just plug in the numbers...I figured I would assume a linear relationship between K and Temperature, so that k = 1.1 + .4T/900 - 100(.4/900). But I'm not sure if that gets me anywhere as for solving the problem. Or...could I just take the average k value to be (1.1+1.5)/2 and use that? I'm not sure what the appropriate way to go about this problem is...
I agree that a good first approximation would use the average thermal conductivity to give
[tex]Q=-\frac{k_1+k_2}{2}\frac{dT}{dx}[/tex]
A better approximation can be found by using the exact governing equation. You can find this by doing an energy balance on a control volume, if you're familiar with that. You'd have
[tex]-k(T)\frac{dT}{dx}[/tex]
going in and
[tex]-k(T)\frac{dT}{dx}+\frac{d}{dx}\left[-k(T)\frac{dT}{dx}\right]dx[/tex]
coming out. (The second term is the first expression in a Taylor series expansion of the first term.) An energy balance gives
[tex]\frac{dk(T)}{dT}\left(\frac{dT}{dx}\right)^2+k\frac{d^2T}{dx^2}=0[/tex]
which is the governing equation. You would likely have to solve this numerically. (If k is varies linearly with T, there might be an exact solution; I just don't know it offhand.)
Thanks! I have a feeling that the professor is looking for the simple average solution, since this was part of a question from a Mat Sci test, on a chapter that just briefly touched on thermal properties of materials.
But it is nice to know some of the uses for these other things I am learning in some of my classes (like Taylor series and math processing software)!
Solution
Hello,
Mapes, I would like to continue in developing a discrete equation to solve numerically. What is the next step and what would be the solution of this equation.
[tex]
[/tex]
After reading around, one have to discretized the above equation, and identify the initial and limits conditions. Your help would be appreciated.
Thank you.
HR
Exactly, you'll discretize as (if I did this right)
[tex]\frac{dk(T)}{dT}\left(\frac{T_\mathrm{R}-T_\mathrm{L}}{2\Delta x}\right)^2+k(T)\frac{T_\mathrm{R}+T_\mathrm{L}-2T}{(\Delta x)^2}=0[/tex]
[tex]T=\frac{T_\mathrm{R}+T_\mathrm{L}}{2}+\frac{dk(T)}{dT}\frac{(T_\mathrm{R}-T_\mathrm{L})^2}{8k(T)} [/tex]
Solve for T at each node and iterate until the solution converges.
I just did this for the case of k(T) varying linearly with T and interestingly enough, the exact solution (11,700 W) is the same as if you use the average value of k = 1.3. So flying fish really had the right idea earlier.
Mapes,
Thank you for your inputs. I don't really understand what you mean by solving for T at each node and iterate until the solution converges.
Please tell me if I am wrong:
solving for T means,
[tex]
T - \frac{T_\mathrm{R}+T_\mathrm{L}}{2}+\frac{dk(T)} {dT}\frac{(T_\mathrm{R}-T_\mathrm{L})^2}{8k(T)} = 0
[/tex]
at each node means,
discretize the domain which is the wall thickness.
Let say
Tl | .T1 .T2 .T3 .T4 | Tr
Tl and Tr are known.
Here is my logic:
I can find an equation for k(T) varying linearly with T,
[tex]
k(T) = 0.0004 T + 1.0556
[/tex]
then,
[tex]
\frac{dk(T)}{dT} = 00004
[/tex]
I don't know what to do next to solve (using MATLAB),
[tex]
Q=-k(T)\frac{dT}{dx}
[/tex]
it look straight forward but I am stock.
Thank you if you can help me more.
HR
You're totally on the right track. You have several simultaneous equations (one for each node):
[tex]T_1 - \frac{T_\mathrm{2}+1000^\circ\mathrm{C}}{2}+\frac{dk} {dT}\frac{(T_\mathrm{2}-1000^\circ\mathrm{C})^2}{8k(T_1)} = 0[/tex]
[tex]T_2 - \frac{T_\mathrm{3}+T_\mathrm{1}}{2}+\frac{dk} {dT}\frac{(T_\mathrm{3}-T_\mathrm{1})^2}{8k(T_2)} = 0[/tex]
[tex]T_3 - \frac{T_\mathrm{4}+T_\mathrm{2}}{2}+\frac{dk} {dT}\frac{(T_\mathrm{4}-T_\mathrm{2})^2}{8k(T_3)} = 0[/tex]
[tex]T_4 - \frac{100^\circ\mathrm{C}+T_\mathrm{3}}{2}+\frac{dk} {dT}\frac{(100^\circ\mathrm{C}-T_\mathrm{3})^2}{8k(T_4)} = 0[/tex]
So you see, the left and right temperatures are relative to the node, not absolute. You can have MATLAB solve these equations by making a matrix of the coefficients and inverting it, but you'll need to iterate because k is a function of T.
Your equation for Q is exactly right, and you need to discretize it too. You should get the same Q between any two nodes (this is a good check on your results).
Mapes,
It is clearer for me. Thank you for your precise and valuable inputs.
I solved the equations using MATLAB (for fun) and I found:
1 node, q = 11,700 W (2 iterations)
11 nodes, q = 10,200 W (115 iterations)
101 nodes, q = 9,935 W (6124 iterations)
1001 nodes, q = 9,901 W (125713 iterations)
10001 nodes, q = 9,899 W (too much iterations)
100001 nodes, q = 9,898 W (way too much interations even with less precision, residue = 0.01)
1. What is the rate of heat loss with two thermal conductivity values?
The rate of heat loss with two thermal conductivity values is the amount of heat that is transferred per unit time between two materials with different thermal conductivity values. It is calculated by using the formula Q/t = kA(ΔT/d), where Q/t is the rate of heat loss, k is the thermal conductivity, A is the cross-sectional area, ΔT is the temperature difference, and d is the distance between the materials.
2. How do thermal conductivity values affect the rate of heat loss?
The thermal conductivity values play a significant role in determining the rate of heat loss. Materials with a higher thermal conductivity will transfer heat more quickly than materials with a lower thermal conductivity. This means that the rate of heat loss will be higher for materials with a higher thermal conductivity value.
3. Can the rate of heat loss be controlled by changing the thermal conductivity values?
Yes, the rate of heat loss can be controlled by changing the thermal conductivity values. By using materials with different thermal conductivity values, the rate of heat loss can be adjusted to meet specific needs. For example, materials with a higher thermal conductivity can be used to increase the rate of heat loss and cool down a system more quickly.
4. How does the rate of heat loss with two thermal conductivity values affect insulation?
The rate of heat loss with two thermal conductivity values is crucial in determining the effectiveness of insulation. Insulation materials with a low thermal conductivity value are better at reducing the rate of heat loss than materials with a higher thermal conductivity value. This is why materials like fiberglass and foam are often used as insulation as they have low thermal conductivity values.
5. What factors can affect the rate of heat loss with two thermal conductivity values?
There are several factors that can affect the rate of heat loss with two thermal conductivity values. These include the thermal conductivity values of the materials, the temperature difference between the two materials, the cross-sectional area of the materials, and the distance between the materials. Other factors such as external temperatures and air circulation can also impact the rate of heat loss.
  • Thermodynamics
  • Mechanical Engineering
