Why is the ac output voltage negative for a common emitter Bjt network?
In summary, the collector current in a common-emitter configuration is fixed, causing the voltage drop across the collector resistor to increase as the collector current goes up and the collector-emitter voltage goes down. This leads to the output being essentially zero at saturation, but for AC signals it can be negative when the input is positive. This is due to the presence of a series capacitor, which removes the DC component and causes the voltage to alternate above and below zero. The direction of the output current is determined by convention, with the reference direction (usually the input signal) assigned a polarity, and the other polarities following from this. Usually, a more positive input leads to an increase in collector current and a decrease in output voltage, shown as a
Evilinside
I get that collector current is fixed so as collector current goes up, the voltage drop across the collector resistor goes up and the collector-emitter voltage goes down. Which is why it is basically zero at saturation. But for ac it is not zero but negative when input is positive. why is this so?
Also why is ac output current chosen to come up, from ground, through the collector resistor for the common-emitter configuration and comes up from ground through the emitter resistor emitter-follower configuration. what actually determines the output current direction when modeling the configuration for ac analysis?
The output of an common emitter amplifier is negative of there is a capacitor in series with the output. This is because a series capacitor removes the DC component that existed on the collector and the voltage then alternates above and below zero after the capacitor.
The convention when doing AC analysis is to take a reference direction ( in this case the input signal) and assign a polarity to it (usually upwards or positive)
The other polarities then follow from this.
Usually it is oposite to what you describe, though. A more positive input produces an increase in collector current which goes from the positive to the negative supply.
An increase in collector current produces a decrease in output voltage, so this would be shown as a downward arrow as well.
Maybe you mean something else?
1. Why is the ac output voltage negative for a common emitter Bjt network?
The ac output voltage for a common emitter Bjt network is negative because of the phase inversion that occurs in the transistor. In a common emitter configuration, the input signal is applied to the base and the output is taken from the collector. As a result, the output voltage is inverted with respect to the input voltage, resulting in a negative output.
2. How does the biasing of the Bjt affect the ac output voltage?
The biasing of the Bjt plays a crucial role in determining the ac output voltage. In a common emitter configuration, the transistor needs to be biased in the forward active region for proper amplification. If the biasing is incorrect, the transistor may enter the saturation or cutoff region, resulting in a distorted or zero output voltage.
3. Can the ac output voltage ever be positive for a common emitter Bjt network?
Yes, in certain cases, the ac output voltage can be positive for a common emitter Bjt network. This can occur when the input signal is very small or when the transistor is biased close to the cutoff region. However, this is not desirable as it results in a smaller amplification and can lead to distortion of the output signal.
4. How does the load resistance affect the ac output voltage in a common emitter Bjt network?
The load resistance plays a crucial role in determining the ac output voltage in a common emitter Bjt network. A higher load resistance results in a larger ac output voltage, while a lower load resistance leads to a smaller ac output voltage. This is because the load resistance affects the amount of current flowing through the transistor, which in turn affects the amplification of the output signal.
5. What are the typical values of the ac output voltage for a common emitter Bjt network?
The typical values of the ac output voltage for a common emitter Bjt network vary depending on the input signal, biasing, and load resistance. In general, the ac output voltage can range from a few millivolts to several volts. However, it is important to note that the output voltage should not exceed the maximum ratings of the transistor to prevent damage.
  • Electrical Engineering
