Just a quick question about the double slit experiment.
In summary, when electrons are shot through the double slit one at a time, it is observed that each electron hits randomly in one of the dense areas of an interference pattern. This is because the probability distribution of where the electron will hit is the same shape as the interference pattern. It is not until many repetitions that the interference pattern emerges, as the individual electron hits appear to be random.
Esoremada
52
If electrons are shot through the double slit one at a time, is it observed that each electron hits randomly in one of the dense areas of an interference pattern, or is it only observed after a long time that the interference pattern emerges?
To rephrase, what I'm asking is whether a single particle hits the wall in many places at once in the form of an interference pattern, like you would observe from a single wave sent through, or whether each individual particle only hits a single random spot on the wall and the pattern emerges after many repetitions.
pattern emerges after many electrons are shot. Each electron makes one mark on the screen.
See this animation of an interference pattern as it appears on the screen. It starts out slowly, one spot at a time, then speeds up so you don't have to wait an hour or so to see the pattern take shape.
I think it would help if you think about it in a different way. A single electron can end up anywhere and the result is totally random. The probability of where it will actually hit depends upon the statistics. The probability distribution is the same shape as the interference pattern. Very unsatisfactory, I know, but that seems to be the way it is.
This is a great question about the double slit experiment. The answer is that the interference pattern only emerges after many repetitions of sending individual electrons through the double slits. This is because each individual electron behaves like a particle and can only hit one spot on the wall at a time. However, when many electrons are sent through, the interference pattern emerges due to the wave-like nature of electrons. This phenomenon is known as wave-particle duality, where particles can exhibit both wave-like and particle-like behavior. So, to answer your question, the interference pattern is not observed for a single electron, but rather emerges over time as more and more electrons are sent through the double slits.
Related to Just a quick question about the double slit experiment.
1. What is the double slit experiment?
The double slit experiment is a famous experiment in physics that demonstrates the wave-particle duality of light. It involves shining a beam of light through two narrow slits and observing the resulting interference pattern on a screen.
2. What is the significance of the double slit experiment?
The double slit experiment is significant because it challenges our understanding of light as either a wave or a particle. It shows that light can behave as both a wave and a particle, depending on how it is observed.
3. How does the double slit experiment work?
In the double slit experiment, a beam of light is shone through two narrow slits and the resulting interference pattern is observed on a screen. This is due to the interaction of the waves from the two slits, which creates areas of constructive and destructive interference.
4. What are the implications of the double slit experiment?
The implications of the double slit experiment are far-reaching and have had a significant impact on our understanding of quantum mechanics. It challenges traditional ideas about the nature of light and has led to further experiments and theories about the duality of particles and waves.
5. How does the double slit experiment relate to other areas of science?
The double slit experiment has implications not only for physics, but also for other areas of science such as biology and chemistry. It has shown that particles can exhibit wave-like behavior, which has implications for understanding the behavior of atoms and molecules.
  • Other Physics Topics
14K
  • Quantum Interpretations and Foundations
20K
  • Quantum Physics
  • Quantum Physics
