Why do metal boxes block EM waves?
In summary, a metal box can block most EM waves because the oscillating E field will be canceled when in contact with the conductor. This is because the oscillating E field is the source of the changing B field, which is then killed. However, good conductors do not necessarily block the EM wave, but instead attenuate it. The amount of attenuation depends on the thickness and frequency of the EM wave. Attenuation can be calculated using the equation e^{-\alpha z}=\frac {V_{out}}{V_{in}}, where \alpha and \beta are constants that are dependent on frequency and conductance. The lower the frequency, the thicker the metal must be to block the EM wave. For audio frequencies, a
cragar
2,552
A metal box will block most EM waves. Is this because the oscillating E field
will be canceled when in contact with the conductor. And because the oscillating E field
is the source of the changing B field does this then kill the B field.
Good conductor attenuate the EM wave, don't necessary block the EM wave. It depends on the thickness and the frequency of the EM wave. For good conductor:
[tex]δ=\alpha+j\beta\;\hbox { where }\; \alpha=\beta=\sqrt{\pi f \mu σ}[/tex]
Attenuation is
[tex]e^{-\alpha z}=\frac {V_{out}}{V_{in}}[/tex]
As you see, it is frequency and conductance dependent. Set the thickness z in the equation to get the desired attenuation( Vout/Vin).
http://en.wikipedia.org/wiki/Skin_effect
it is not true that metal plates will block EM waves.it depends on the plasma frequency of metal,if it is below the incident frequency there will be transmission of EM waves.
http://en.wikipedia.org/wiki/Plasmon
If you look at the formula, the lower the frequency, the thicker the metal has to be to block the EM wave. In guitar magnetic pick call Lace Sensors, they are known to be lower noise than other regular single coil pickups. They have the coil in a tub like ferromagnetic material that is about 1mm or more thick. It needs much thicker to block audio frequency EM wave. For microwave, very thin material will do, but then you have to worry about little holes and crack of the cage as any opening comparable to the wavelength will allow EM to weak out.
Yes, this is correct. When an electromagnetic (EM) wave enters a metal, the oscillating electric field will induce a current in the metal, which will then produce its own electromagnetic field. This new field will be in the opposite direction of the original EM wave, effectively canceling it out. This is known as reflection. As a result, the changing magnetic field associated with the EM wave will also be canceled, effectively "killing" the B field. This is why a metal box is an effective shield against EM waves - it reflects and absorbs them, preventing them from passing through. This principle is also utilized in Faraday cages, which are used to block out external electromagnetic interference.
1. What is an EM wave?
An EM wave, or electromagnetic wave, is a type of wave that is made up of electric and magnetic fields. It is a form of energy that can travel through space. Examples of EM waves include radio waves, microwaves, visible light, and X-rays.
2. How does an EM wave interact with metal?
When an EM wave comes into contact with a metal object, the metal absorbs the energy of the wave and converts it into an electrical current. This is known as the "skin effect" and is a result of the metal's high electric conductivity. The EM wave also causes the metal's electrons to vibrate, creating heat.
3. Can EM waves pass through metal?
In most cases, EM waves cannot pass through metal. This is because the metal reflects and absorbs the energy of the wave. However, some EM waves, such as radio waves, can pass through thin layers of metal, but they will still experience some reflection and absorption.
4. How does the thickness of the metal affect the interaction with EM waves?
The thickness of the metal can affect how an EM wave interacts with it. Thicker layers of metal will absorb more energy and result in a greater skin effect and heat production. Thinner layers of metal will allow some EM waves to pass through, but they will still experience some reflection and absorption.
5. Can EM waves change the properties of metal?
Yes, EM waves can change the properties of metal. When an EM wave is absorbed by metal, it can cause the metal to heat up and potentially change its physical properties. This is why metal objects can become hot when exposed to sunlight or other sources of EM waves.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
