Building a battery that will last for centuries
In summary, the conversation discusses the design and construction of a traditional mechanical pendulum clock that can accurately function for centuries. The clock will require electricity to micro adjust the pendulum amplitude, which will be generated by the pendulum itself and stored in a special rechargeable battery. The design includes incorporating artistic elements into the battery plates and using solenoids, gears, and levers for mechanical parts. The clock will also be synchronized with atomic clock signals and have the ability to adjust for daylight savings time. The conversation also mentions the possibility of using a Silicon-Air battery or a Nickel-Iron battery for long-lasting power.
TheClockmaker
I want to make an heirloom mechanical pendulum clock that is very tradition in design and yet will accurately work for centuries—and so I want to micro adjust the pendulum amplitude automatically and that requires some electricity, not very much electricity, but it will take some small amount of electrical power to run the micro circuit and to activate a solenoid that will kick a gear one tooth click forward or backward to micro adjust the pendulum length.
I will generate electricity from the pendulum as it swings past a coil and so now I need a special battery—a zero maintenance (or ultra-low maintenance) rechargeable low voltage battery that will work for many centuries, even a millennium if I can. Is this possible and how?
The plates can be large in size if needed; I can store them vertically on the back of a grandfather clock design, or stack them as several plates at the bottom of the clock, or both; I even like the idea of sculpting the metal in a way so that it’s artistic while also storing the power—even if I have to store this art behind glass to protect the energy store this is fine, but I do plan to carve some art into the plates, not simply have them as plates.
If you have any battery design suggestions please let me know.
For those curious about my design, I use the atomic clock signals to keep the clock in sync. My goal is for this to stay accurate within 0.5 second, and if I can do better than this I will. It all depends upon the battery—more energy allows me to micro adjust more often and increase the accuracy.
For daylight savings time I will adjust the time quickly using solenoids that will disengage the standard clock movement and instantly perform the correct 1 hour movement within seconds and move the minute hand forward 1 minute—the clock will sit there motionless for the remainder of the minute and will then resume normal operation; this adjusts the clock to normal time within 1 minute and then more frequent micro adjustments will be performed during the next few minutes to keep the clock accurate.
I intend to use fuzzy math to keep my clock in sync using these micro adjustments and an atomic clock as my source of truth.
I plan to use solenoids, gears and levers and my only mechanical parts because they can be designed to last for centuries.
I hope to make several as gifts to family if successful; I’ll make them out of soft metals, and perhaps even a combination of wood and metal. For the gears, I may clad wood over the top of the metal gears to give it some beauty, but the actual gear on gear touching will be metal not the wood because I am truly hoping to make something that will last for centuries.
Assuming that atomic clock signals may change in the centuries to come I will make my circuit easy to swap out to something newer.
Mark
It seem that the Silicon-Air battery has some promise in the somewhat near future. I am hoping that i can use my low energy needs to my advantage, especially since I have the needs of a small AAA battery with size capacity afforded to a golf to a golf cart.
So I want to see if I can use this in a way that makes the battery last a long time and is rechargable. For example, If I have large surface area, can I simply lay one on top of the other with some form of potassium hydroxide paste acting as the electrolyte?
I could cut parallel lines of sawtooth groove into the plates and mesh them into each other to maximize surface area. I'm just trying to learn what I can do to make a very long lasting battery. Any suggestions are appreciated. Thanks.
Because you have a continuous source,(the pendulum, and whatever mechanical keeps the pendulum going.) You might be able to use a large capacitor to run you circuit and adjuster. Part of this depends on the duty cycle of the items you want to run. Just an Idea!
The pendulum will swing mechanically from weights that will be reset manually, so the kinetic energy is endless as long as the owner cares for it.
I'm going to make a new post and ask for a specific request on how to make a Nickel-Iron battery last the longest--this seems like my best choice, unless I hear differently from someone or this Silicon-Air battery design from the Israeli's becomes viable over the next few years.
Thank you for sharing your design and goals with us, Mark. It is certainly an ambitious project to create a battery that can last for centuries. While it may be challenging, it is not impossible. There are a few key factors to consider in designing such a battery.
First, the materials used in the battery must be durable and have a very long lifespan. Traditional batteries use chemical reactions to generate electricity, but these reactions can degrade over time. One possible solution could be using a solid-state battery, which uses solid materials instead of liquids to store energy. These types of batteries have the potential to last for much longer periods of time.
Another consideration is the type of energy source used to recharge the battery. You mentioned using the swinging motion of the pendulum to generate electricity, which is a great idea. However, it may not be enough to fully charge the battery. You may want to consider incorporating other sources of energy, such as solar or wind power, to ensure that the battery is constantly charged.
In terms of design, you mentioned using large plates to store the battery. This is a good idea, as it will allow for more energy storage. However, it is important to also consider the weight and size limitations of the clock itself. You may need to find a balance between size and energy storage capacity.
As for the aesthetics of the battery, using soft metals and incorporating wood can add a nice touch to the design. However, it is important to ensure that the materials used do not interfere with the function of the battery and its ability to hold a charge.
In terms of keeping the clock accurate, your use of atomic clock signals and micro adjustments is a great idea. However, it is important to also consider the potential for changes in atomic clock signals in the future. As you mentioned, making the circuit easy to swap out for a newer one is a good plan.
Overall, creating a battery that can last for centuries is a complex task, but with careful consideration of the materials, energy sources, and design, it is possible. Good luck with your project, and we look forward to seeing the final product!
FAQ: Building a battery that will last for centuries
What is the purpose of building a battery that will last for centuries?
The purpose of building a battery that will last for centuries is to provide a long-term and sustainable energy storage solution. This is especially important as the demand for energy continues to increase and non-renewable resources are being depleted.
What materials are needed to build a battery that will last for centuries?
The materials needed to build a battery that will last for centuries are typically durable and long-lasting materials such as lithium, nickel, cobalt, and other rare metals. The battery must also have a highly efficient and stable electrolyte to facilitate the flow of ions between the electrodes.
How is the longevity of a battery determined?
The longevity of a battery is determined by several factors, including the type and quality of materials used, the design and construction of the battery, and how it is used and maintained. Proper care and maintenance can significantly extend the lifespan of a battery.
What are the challenges of creating a battery that will last for centuries?
One of the main challenges of creating a battery that will last for centuries is finding a way to prevent degradation and corrosion of the electrodes and electrolyte over time. This requires extensive research and development to find the most durable and stable materials and designs.
What are the potential benefits of a battery that will last for centuries?
A battery that can last for centuries would provide numerous benefits, including reducing the need for frequent battery replacements, decreasing the reliance on non-renewable energy sources, and reducing the environmental impact of battery production and disposal. It could also lead to more efficient and sustainable energy storage solutions for various industries and applications.
32K
